Cable driven speedometer that jumps to 120 mph but later drops.
I wonder if the cable inside the cable sleeve is binding causing it to wind-up.
Then as tension builds it releases causing the over-spin of speedometer.
If that is the case then maybe the removal and review of the cable might provide some answers.
Cable driven speedometer that jumps to 120 mph but later drops. I wonder if the cable inside the cable sleeve is binding causing it to wind-up.
The only time I've had one bind up it twisted itself in half.
Oiled it up. Last year used that wax stuff, thinking it's to sticky, speedo was stiff. Don't seam to be any replacement for this year. hoping that takes care of it maybe caught before totally trashed it. Every time it has wound up I've slowed to almost stop so it don't wreck it.
Just said they couldn't get one. Searched the number on line seen someone on Craig's list searching for one. I probably should get I used off eBay seeing as there hard to come. Time to ride, hope oil don't get on brakes
I'm willing to bet that they didn't try.
Some parts guys aren't very good.
