jet size question
Old Aug 4, 2016 | 05:14 PM
langwilliams's Avatar
langwilliams
Default jet size question
my bike is running very rich...I thought I'd adj the AFR adj...I tried to turn it in to back out to 2.5 turns for a base starting point, turns out it's all the way in. I'm off the week of labor day an plan on taking a look at it then.....should I down size the idle jet one size or two? I don't know what it has in it now so I'm just going to take a look an go a smaller one.
Old Aug 4, 2016 | 05:51 PM
Uncle G.'s Avatar
Uncle G.
It would help if you mentioned what bike you have and what carburetor you're running.
The pilot jet and mixture screw tune the mixture from idle to 1/8 throttle in general. If you're running rich at larger throttle opening you will need to look elsewhere.
On a Keihin CV carb, the mixture screw meters fuel, and turning the screw in leans the mixture. On a Mikini HSR, the mixture screw meters air, so turning in the screw makes the mixture richer.
Old Aug 4, 2016 | 08:31 PM
langwilliams
it's a CV.....the bike is a 99 fatboy with a v thunder 3010 cam. I'm also getting fairly poor mileage...32 on a good tank 28 on the low end.
Old Aug 4, 2016 | 09:41 PM
Racepres's Avatar
Racepres
It Just started this Behavior?
Or...after which Modification??
Old Aug 5, 2016 | 09:47 AM
Uncle G.'s Avatar
Uncle G.
Poor fuel economy is usually an overly rich pilot jet or jet needle. A well tuned CV carb is capable of 45-50 MPG on the highway (at least that's what I used to get with mine).
What air cleaner/exhaust are you running? Have you changed anything lately? It sounds like the pilot circuit and/or jet needle is very rich, or you're running it VERY hard.
Old Aug 5, 2016 | 05:50 PM
langwilliams
I don't run hard a lot but I'm not afraid of the throttle either......the plugs look pretty black after a few tanks of gas. I'll take a pic of the ones I just took out if I still have them. The first time I changed the plugs they were showing indications of a rich condition. I have a patriot defender short 2 into 1 an k&n filter with aftermarket backing plate so I could ditch recirculating the oil that's vented. the bike starts up fine an runs great.....it's smooth as silk cruising around town an back roads at 2300-2650, I cruise in that range since it seems to be the smoothest.
Old Aug 5, 2016 | 05:53 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
A sure sign of running rich.
Old Aug 5, 2016 | 06:52 PM
langwilliams
here's a pic of the front plug....the rear is a little cleaner but not much:
maybe I can just run some seafoam through it....works for traildog!
Old Aug 5, 2016 | 06:53 PM
langwilliams
that's after a little over 3 tanks.
Old Aug 5, 2016 | 07:11 PM
texashillcountry
Dirt don't hurt
Yeah your jets or afr is way off!!!
I'd try adjusting the A/F mixture screw first.
