Seat bolt replacement
Old Aug 4, 2016 | 09:27 PM
CBCanada's Avatar
CBCanada
Default Seat bolt replacement
Hey folks
I lossed the bolt that screws my seat down. Went to the Harley dealership got a replacement bolt today but what they gave me is not long enough, I am attaching a picture of my seat. Do I need a special size for this? The seat is a Harley seat, it says Harley Davidson right on it so I assume it's oem
The bike is a 96 fatboy
Old Aug 4, 2016 | 09:33 PM
QC's Avatar
QC
It should be 1/4-20 in size. A well equipped Ace Hardware may have some chrome ones of varying lengths and you should be able to find one that'll work.
Old Aug 5, 2016 | 05:58 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by CBCanada
Hey folks
I lost the bolt that screws my seat down. Went to the Harley dealership got a replacement bolt today but what they gave me is not long enough, I am attaching a picture of my seat. Do I need a special size for this? The seat is a Harley seat, it says Harley Davidson right on it so I assume it's oem
Then get a longer bolt.
Just because something says HD doesn't make it OEM to your bike.
Old Aug 5, 2016 | 06:01 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Here's a couple of places to looook......
Cut them down if the length is too loooong....
https://www.amazon.com/s/?ie=UTF8&ke...l_1y33mvt6x0_e
https://www.grainger.com/product/GRAINGER-APPROVED-Thumb-Screw-5PY67?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/5PY57_AS01?$smthumb$
Old Aug 5, 2016 | 06:11 AM
texashillcountry
Dirt don't hurt
Or you can go to your local hardware store.
FWIW that bolt on my bike is 1/4 28.
If you do cut it down make sure you get a nut threaded on the bolt before you cut it.
That will help you straighten out the threads after cutting.
Old Aug 5, 2016 | 07:46 AM
Crashone's Avatar
Crashone
1/4-20 x 3/4 to 1" will work with a lock washer and regular washer. You can buy the Allen key heads in stainless steel at Ace, Lowes and most likely a home depot. Put a little blue locktite on it and it'll stay there.
Old Aug 5, 2016 | 09:02 AM
Uncle G.'s Avatar
Uncle G.
Mine is also a 1/4-28 (Unified National FINE thread). You can get nice stainless button head screws in any well stocked hardware store.
Old Aug 5, 2016 | 09:15 AM
Uncle Larry's Avatar
Uncle Larry
#5 2952A SCREW 1/4-20 X 1/2 SEMS truss hd. | BJ96/BK96/BL96/BM96/BN96/BP96
According to the listing it's 1/4 -20 x 1/2 inch long ... just get one a bit longer.
http://www.stcharlesharleydavidson.c...A%5cX49%5cBM96
Old Aug 5, 2016 | 09:32 AM
im's Avatar
im
My understanding is that standard size is 1/4 X 20 for thickness and thread.
The length being about 1/2 inch.
Numerous choices on e bay and such.
Ace Hardware has a good selection of bolts also.
The head of the bolt becomes the limiting factor but a chrome metal washer and rubber gasket can resolve the issue.
Some license plate security bolts are of the same size but strength is unlabeled.
Caution with using too long of a bolt as a lowered bike might cause bolt to scrub against tire.
Lift the seat and try the bolt you got at harley then you can re-confirm the size at Ace Hardware using their "fit" display and get one slightly longer.
Do not forget the chrome washer and a thin rubber gasket to help against loosening vibrations.
The rear fender cover looks rather thick and looks like it adds at least 1/4 inch thickness with the chrome metal and black backing combination.
Then add the usual problem of the first few threads in nut portion being stripped and it will not grab.
Old Aug 5, 2016 | 10:52 AM
Beemervet's Avatar
Beemervet
I once cut a new rain groove into a tire.
You don't need to ask how..........
