Keep the old speedo and/or a receipt showing the mileage in case you sell the bike and want to prove it.
Meantime, just ride.
The old speedo just spins in circles and the mileage doesn't display anymore. the most i get is the trip meter reading .1
Originally Posted by Crashone
Have you contacted the manufacturer of the new speedo and asked them? Seems like they would know. Look around your area for a speedo repair shop, or did all of these go out of business? Check with local Indy repair shops.
Checked two local indy who gave me numbers to try. 3 harley dealers that said they couldn't do anything. the speedometer is a new-old stock replacement part. It was sitting on my friends shelf for years. In the original box unopened.
Originally Posted by im
Did you get the black-out of LCD odometer on the old unit?
There was no black. Im familiar with this problem though. The old speedometer would just jump around and read between 60-120 mph.
OP if the LCD screen was blacked out IM helped me out with directions on how to change out the screen. On your bike the mileage is retained in the speedo itself so if you change the new screen to your old unit your mileage would be correct.
The unit went bad. No black screen.
Thank you for all the replies! The unit is brand new made in 1996. Its a really small problem.. but I kind of want the miles back on cause it was my dads.
To be clear.
The old unit would jump, inconsistent MPH reading correct?
Meaning the needle would swing from left to right but give an incorrect speed correct?
It did not actually spin in a circle 360 degree's like a fan correct?
The odometer is not recording miles correct?
Just want to make sure you have reviewed the speed sensor.
The speed sensor will build-up metal shavings some times.
The inability to maintain a consistent reading would cause the needle to fluctuate between speeds and the odometer would be unable to record miles traveled.
That speedometer has about 12 wires and is a bit of pain to change-out.
Just want to make sure you have full information and do not end up frustrated due to a speed sensor issue.
I changed the one on my 83 shovel an 94 fxstc an just marked the title inaccurate mileage when I sold it....it hurts resale some but you do what you gotta do.
Do not throw the old unit away.
The LCD screen can by used for repairs.
still got it!
To be clear.
checked speed sensor. already replaced speedometer. it went bad. the speedometer..
Originally Posted by Spanners39
The factory can do it but I am sure they will take ages and charge you heaps.
where can I contact someone who will help me do this?
Originally Posted by Uncle G.
My speedometer hasn't read the correct mileage since I rolled it over from "99,999,9" to "00,000.0" back in '03.
That is a beautiful thing!
Not trying to sell it. It was my dads bike. It had really low mileage because the guy that bought it had major back surgeries and could no longer ride it. Held on to it with hopes he would be able to ride it again. Bought it with 11,500 miles on it.
