Fuel Petcock Leak
Old Aug 14, 2016 | 06:27 PM
FatboysFatboy96's Avatar
FatboysFatboy96
Default Fuel Petcock Leak
My folks loaded my bike on their toy hauler and took it to Sturgis so I could fly in. On the way my dad discovered the petcock was leaking fuel. In a rush I had JP Cycles ship one to the campground. The one they sent does not have the vaccume cut off that the OEM petcock had. I installed the new one and plugged the hose off so I could ride while here. The bike performed flawlesly, but I could occasionally smell fuel where I didn't before. Is that normal? The OEM looks rebuildable and I would like fix it but they don't seem to be available in the aftermarket. Any clues on where to find one?
Old Aug 14, 2016 | 06:38 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Have you tried the dealer?
Old Aug 14, 2016 | 06:49 PM
nibroc's Avatar
nibroc
contact pingle
Old Aug 14, 2016 | 07:31 PM
texashillcountry
Dirt don't hurt
Originally Posted by nibroc
contact pingle
Pingle does have a vacuum operated petcock but it's over $200.
Old Aug 14, 2016 | 09:28 PM
FatboysFatboy96
Ouch! As I browse the interwebs it appears that I may be better to leave this set up and capping off the vaccume line more permantly. I'm not liking the fact that smell gas at times. I can't see anywhere where gas is dripping from, All my hoses seem tight, and the carb isn't leaking anywhere.
Old Aug 14, 2016 | 09:44 PM
Prot's Avatar
Prot
You are overthinking this, which seems to be a common thing with petcocks lately.
One or two years ago mine was leaking. Picked up a new OEM one at the dealer. It had the vacuum connector on it. It came with two sized strainers. It was an improvement over the original because the new one makes a clicking noise you can hear and feel in each position.
Nut on the new one had threads with too many burrs in it to go on like it should so I reused the old nut.
New petcock with an old nut. For some reason that sounds funny.
Old Aug 14, 2016 | 09:50 PM
FatboysFatboy96
What did it set you back $$wise? Not that I'm a tightwad, but I do have a budget and this is a toy.
Kabear's Avatar
Kabear
After the bike is shut down the engine continues to heat the area around the carb. This causes expansion and the fuel smell is probably coming out of the carb intake. You don't see the fuel because the air filter absorbs it.
OR:
The vacuum line isn't completely sealed off. And the fuel smell is coming from that.
Try shutting off the fuel a few seconds or so before shut down and see if that helps, allowing the engine to idle on just enough fuel to assure the level is lowered in the fuel bowl on the carb.
Old Aug 14, 2016 | 10:11 PM
Prot's Avatar
Prot
I don't remember but since I don't remember it probably wasn't much. If it was expensive I would probably remember. Besides, the OEM one lasted over twenty years, so I figure that's a decent enough service life for an inexpensive part.
BTW, bookmark the site below. It is very easy to look up OEM part numbers. I used it to eventually locate brand new but old stock saddlebags.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old Aug 15, 2016 | 04:20 AM
Yankee Dog's Avatar
Yankee Dog
I would keep the "old style" non vacuum petcock. Your probably smelling fumes because your looking for them because of your recent issue...double check your fuel lines and connections just to be sure. Might have had the fumes there all along (from air cleaner) and because of your recent problem you are more aware.
As long as there is no leaks, make sure vacuum line is plugged and leave well enough alone. The vacuum type petcocks can be problematic at times. The old style is "simple". Less to go wrong in the future. YD
