Some thoughts on this please.
Old Aug 30, 2016 | 04:02 PM
JesseDyna's Avatar
JesseDyna
I think my Twin Cam manual says to crack the enricher a bit after a bit of off time even when still warm so it's not that crazy. If you have a musical ear, you can listen to some of the vids on youtube with an idling bike at the prescribed rpm and then tune to pitch. There are apps you can use to record audio and use a graphical display such as in the program Audacity to figure out rpm with a little math. Or you can buy one of those cheap $10 tach/hour meters on Amazon.
I use the latter option and it works great. I don't care about "lope" or a "fashionable" idle - i care about proper oil to the engine and I set to my prescribed 1000 rpm after a full warmup.
Old Aug 30, 2016 | 04:18 PM
Dazzauk's Avatar
Dazzauk
Cheers Jesse. I agree with you I'd rather have the engine working properly than have the slow lumpy idle sound even if it does sound great.
Old Aug 30, 2016 | 05:18 PM
RANGER73's Avatar
RANGER73
You could get a mini gauge and a bracket that mounts to the rocker box cover. just get one compatible to your bike and follow the instructions. If it's not EFI the coil, if it is the control box might have a TACH port.
Old Sep 2, 2016 | 10:36 AM
Uncle G.'s Avatar
Uncle G.
My bike has always been like that to some degree. If I shut it off for say a half hour or an hour, she'll fire right up with no enrichener, but will die if I let it idle. There seems to be a "zone" where the bike will start without the enrichener, but doesn't quite want to "run" without a bit of it.
It's always done it, so I don't worry about it.
Old Sep 4, 2016 | 07:59 AM
Hey Man's Avatar
Hey Man
Originally Posted by Dazzauk
Reason being is for me the bike is 100% period and to add a rpm gauge up top would maybe spoil it's period looks.
???? And just what "period" would that be?"
Old Sep 4, 2016 | 02:09 PM
Yankee Dog's Avatar
Yankee Dog
If you don't want to install anything, then pick up a tach on fleabay for a two cylinder motorcycle, attach a length of wire with alligator clips or crimp-on connectors and use the tach as a handheld tool...Yes the tach will not be the most accurate, but it will get you close.
Lots of instructions on google on how to wire it up. YD
Old Sep 4, 2016 | 04:37 PM
Dazzauk's Avatar
Dazzauk
Ah man this is bike is so 90's
Old Sep 5, 2016 | 06:29 AM
Hey Man's Avatar
Hey Man
So I guess it must be pretty "fly" then.
Old Sep 5, 2016 | 06:48 AM
jamesroadking's Avatar
jamesroadking
an "RPM Gauge" is a Tachometer.
Old Sep 5, 2016 | 06:57 AM
Dazzauk's Avatar
Dazzauk
Lol yes sir
