weird turn signal issue
Old Oct 6, 2016 | 08:43 PM
langwilliams's Avatar
langwilliams
Default weird turn signal issue
my left front turn signal/running light on my 99 Fatboy started acting weird...both elements in the bulb burn all the time but it still flashes when you turn on the turn signal...hope this doesn't indicate a bad module. Today the bright running element blew....going to get a new bulb tomorrow but it doesn't sound like a bulb problem...anyone seen anything like this before?
Old Oct 6, 2016 | 09:03 PM
81rat's Avatar
81rat
The very first thing is to check and clean the grounds and check to make sure that 1 of the terminals on the bulb is not contacting both terminals in the socket , most likely you have a ground problem , clean with sand paper
Old Oct 6, 2016 | 09:49 PM
langwilliams
I pulled the lens today an it looked normal...looks like the socket is rivited in place so you can't pull it an check the wires on the back.
Old Oct 7, 2016 | 04:54 AM
grbrown's Avatar
grbrown
Check the wiring to that lamp. Classic symptoms of electrickery finding the path of least resistance - in other words not going where its supposed to!
Old Oct 9, 2016 | 09:36 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Are the rear signal lamp and dash indicator working normally?
Old Oct 9, 2016 | 08:58 PM
langwilliams
yes dan it all works normal other than both elements on the whole time. thinking back it seems it started when I did a hard hit on the throttle...wonder if the vibs did something...haven't had time to look at it.
Old Oct 10, 2016 | 09:10 PM
langwilliams
today I looked in the socket an scraped a little screwdriver around an a little strand or shaving came out.....put a new bulb in an it's fine....never heard of that.
SoCal Bob
Dec 18, 2014 08:56 AM
jamc1103
Nov 22, 2013 06:29 PM
BlackPearl#1
Sep 25, 2012 08:02 AM
Rock Chalk
Feb 28, 2012 09:50 PM
homyakchik
Mar 10, 2009 03:14 PM
