Misfiring 1992 FXDC
On the point of getting it off the bracket, here's a photo so you can see the "lock washer" that I dont know how to remove...unless just break it? and a photo of where its connected on the engine bracket.
I have a cheap vacuum test kit from Harbor freight that I use to create vacuum, but I know you don't have such a thing over there.
Here are some on Ebay
On opening it up they found this......the previous garage/owner I bought it from had put either the wrong piston rings or have been put on wrongly or wrongly gapped, either way they have totally scratched up my cylinders so there is a compression problem - even i can see this would be a problem. Damn and Blast!
So I've asked them to give me a quote on fixing this by replacing the 2 cylinders and rings, I think they can still use the original pistons. Funnily enough I thought the top of the pistons would be in a worse condition, they look quite clean.
They are looking at honing the cylinders or replacing...any comments from you guys on preference or cheapness - sadly i cant afford to go for the increase cylinder size which would make sense now...Christmas is coming etc.
Well, thats where we are, I'll keep you posted if there's interest.
Neither the cylinder or piston look good. I think you're are going to have to either bore the cylinder or get a new jug. But when I was over there it amazed me at what some of those shops could do fix something and get you back on the road is short order. But I was also riding a Bultaco back then. Maybe christmas will come early and you can do the whole top end. Good Luck!
Oh well, 6 months on and now I hope to start enjoying her and sorting out all the other aesthetic bits! No doubt I'll be back with questions soon. Thanks guys.
Ride safe.
