99 fatboy spark problem
Old Oct 25, 2016 | 07:29 PM
Mikew90's Avatar
Mikew90
Default 99 fatboy spark problem
Hi everyone thanks for viewing I purchased a 99 fatboy with the carbed evo on Saturday with 24100 miles. Bike ran great for 140 miles I changed the engine oil and primary oil with Mobil 1. Although on the way home I was cruising I'm fifth gear and engine shut off. Checked for spark none found I let it sit for twenty minutes fired right up and run again for two miles. Then again same thing continued this process for ten miles. I found the ignition pickup melted today and feel this is the problem. Sorry I am ordering a manual this week just missing the last little bit of prime riding time this year. Could the melted sensor be the problem or am I fighting a losing battle and I should look člsewhere.
Old Oct 25, 2016 | 07:49 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Yes it could very well be your problem.
Whether it is or isn't all of your problem it needs to be replaced.
Old Oct 25, 2016 | 08:08 PM
Mikew90's Avatar
Mikew90
I felt that way also I have been searching high and low just to find mixed answers on that question I thank you very much I hope to fix it tom. And ride it as much as possible it's is so much ore enjoyable than all other bikes I have owned
Old Oct 25, 2016 | 09:16 PM
langwilliams's Avatar
langwilliams
check you ground cable an maybe this:
https://www.hdforums.com/forum/softa...le-riding.html
Old Oct 27, 2016 | 05:49 PM
Mikew90's Avatar
Mikew90
Just wanted to say thanks everyone who offered advice. I installed a older sensor today and just reused the original terminals. Bike broke down again after two miles not sure if I couldn't see it before or what but had spark but found that the Petcock was not feeding fuel unless on reserve. Ordered a petcock from jp today runs great on reserve though just wanted to say thanks and close this. I cleaned my ignition switch and cleaned the grounds to try to prevent future problems.
mregner
Aug 27, 2017 06:27 AM
younggeezer
Mar 14, 2014 10:41 PM
fxr89ci
Dec 4, 2012 09:07 PM
buyingbuyer
Mar 29, 2010 11:09 AM
jentony20
Jul 31, 2009 04:49 PM
