LED Lights (headlights, turn signals, etc)
Old Nov 4, 2016 | 08:26 AM
IBDAGRIZ's Avatar
IBDAGRIZ
Originally Posted by glidein wide
I purchased a led light bulb at the steeler for $75. It replaces the H4 holegen but would not fit into the bucket deep enough due to the fan on the bulb,I needed about a 1/4" more depth to get the lens and ring seated, I also have a diamond cut lens to direct the light but I will never know how it would have been, sucks cuz I didn't want to spend $400.on a headlight.
Don't know if you have the same type of bucket as a dresser does on your WG, but I cut out the back of the bucket on one I bought for my dresser to run the LED headlight. Pretty much just left the outside ring as most of the cone was cut out.
Griz
Old Nov 4, 2016 | 07:05 PM
glidein wide's Avatar
glidein wide
Originally Posted by Prot
What kind of bike and what size light? I am on the mobile app tonight so I don't see everything. I might have some ideas or resources available.
Lighting is a big deal to us Jeepers. Still have a couple of more lights to install on my Jeep's bumper.
86 wide glide with Oem 5" bucket...
Old Nov 7, 2016 | 05:41 AM
Prot's Avatar
Prot
I've been kind of busy with stuff, but did do a little bit of checking and so far only found JW Speaker LED headlights for you. While certainly a quality product, they also are expensive. Apparently Truck Lite does not make one the size you need.
I am still checking around.
Hella or Cibie may have something affordable that could work for you. Not LED, but definitely a quality light.
Old Nov 7, 2016 | 11:26 AM
d24112's Avatar
d24112
5 or 5.75
http://www.ebay.com/itm/Black-5-3-4-...-/322245810049
Old Nov 8, 2016 | 09:15 AM
DeputyLoud's Avatar
DeputyLoud
Thanks for all the info!
Old Nov 8, 2016 | 10:56 PM
Tony_N's Avatar
Tony_N
I'm running the Truck-Lite head light and passing lamps, Custom Dynamics fender tip lamps, tail light board, front and rear turn signals with the Smart Triple Play and signal stabilizer.
johntaylorny
Dec 3, 2019 02:10 PM
Passing Lane
Dec 7, 2018 06:56 AM
jimmyk61
Jan 12, 2016 11:33 PM
dc1450
Feb 23, 2013 06:46 PM
Garemlin
Oct 25, 2010 09:30 AM
