ev27 install...little problem
Old Nov 2, 2016 | 06:19 PM
800screws's Avatar
800screws
Default ev27 install...little problem
well, I thought I ruled doing my first cam swap...took like 15 minutes! lol...everything is lined up, wheel spins....except when the cone is put back on...then nothing moves...no pushrods installed yet..i don't have a dial, but I read on the nightrider instructions to use a .055 spacer which I did.....I imagine the spacer is too thick.... it goes bearing, thrust washer, spacer, then cam? right?
does the ev27 cam need the spacer on a stock 80" evo? or am I missing something?
Old Nov 2, 2016 | 06:59 PM
misfitJason's Avatar
misfitJason
You need to check endplay of the cam. There is not set amount. It totally depends on your bike what size spacer you will need. And just to double check. The order should go like this
I think the endplay calls for .010-.040
Old Nov 2, 2016 | 07:08 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
For a stock cam it's 10-50 thousandths.
Not sure on the bottom number but I'm sure about the 50 thousandths.
For the EV-27 its 8-15 thousandths.(If memory serves)
Old Nov 2, 2016 | 07:10 PM
texashillcountry
Dirt don't hurt
Nothing should move if the cam gear is touching the pinion gear.
Unless you rotate the motor somehow (usually by turning the rear wheel).
Old Nov 2, 2016 | 07:13 PM
apples402's Avatar
apples402
You have to check the end play through the lifter block bore..block removed, rear worked best for me, feeler gauge between the cam and spacer or (thrust washer), run your timer cup bolt in the end of cam and this helps move the cam in and out. I think the older bikes may not need a shim, but I am not certain of the year break, seems everyone shoots for the .010 setting but the service manual I believe allows up to .050. BTW the lifter blocks are 12 pt 1/4" and you need a good socket with a lot of patience.
Old Nov 2, 2016 | 07:48 PM
800screws's Avatar
800screws
I have the 12 point socket. I measured the two cams and have a .05 difference between the two. Is .0005 difference gonna jam it up like that with the cone on?
Old Nov 2, 2016 | 07:49 PM
800screws's Avatar
800screws
yeah I'm turning the rear wheel
Old Nov 2, 2016 | 08:02 PM
apples402's Avatar
apples402
I am assuming the stock cam is .050 longer, correct? The .005 ( with shim) added length may do that if your original cam's endplay was closer than .010. Question..does your thrust washer have the tabs? If so the tabs should be lower in the rear so the flat spot clears the rear lifter block. You may need to use a .050 shim or less, this will be based on your measurement of actual end play. Also, you do have the gasket in place right?
Old Nov 2, 2016 | 08:19 PM
Hackd's Avatar
Hackd
My 93 used a shim when I had the EV27 put in.
Old Nov 2, 2016 | 08:26 PM
apples402's Avatar
apples402
I'm thinking it may be the 84's to 88 or 89. I think in the Andrews install instructions there was something about that, I'll look for them. But I believe 800's situation will be needing a shim based on the difference in cam length.
