lowering blocks
Old Nov 6, 2016 | 07:50 PM
Owtlaw's Avatar
Owtlaw
Originally Posted by grbrown
I wouldn't use lowering blocks, not least because they ain't an engineering solution! I will also argue that unless you are very short legged you don't need to lower a Harley either, because it isn't necessary to flat-foot - something I haven't been able to do for decades!
I second that. Flat footing is overrated. The proper stop is keeping the right foot on the brake and leaning over on the left.
Old Nov 6, 2016 | 08:33 PM
langwilliams's Avatar
langwilliams
lowering a touring bike for me was more about being able to back it in...hard to do on your toes.
Old Nov 7, 2016 | 07:54 AM
galtjunk's Avatar
galtjunk
Try Arnott air suspension.
You can dump all of the air out to back in to a spot.
If you use an onboard compressor you can pump it right back up for riding.
I use the Alden shocks supplied with the compressor from Arnott.
You can adjust the ride while you are rolling.
Best money I've spent.
Old Nov 7, 2016 | 08:06 AM
grbrown's Avatar
grbrown
Lightbulb
Which is why we shouldn't attempt to! Too risky and not something any training school will teach. Get off the darned thing and push from beside it! Don't try to be lazy by staying seated, or you may end up on the floor. No need to lower it at all.
Old Nov 7, 2016 | 09:51 PM
langwilliams
I had an air ride an always had problems with it so I gave up on it
Old Nov 7, 2016 | 11:35 PM
Prot's Avatar
Prot
How thick is your current seat? Maybe a slimmer seat is all you need to get better planted. Besides the thickness, the width also comes into play, especially towards the front of the seat.
Old Nov 8, 2016 | 05:15 AM
grbrown's Avatar
grbrown
Also a good footing starts at the ground! A heavy soled pair of good quality riding boots can give a little extra reach, as well as a better purchase on terra firma.
Old Nov 8, 2016 | 08:22 AM
langwilliams
I have a 29.5" inseam an I went with the shorter 12" shocks off a newer street glide an as flat a seat as I could find an still put 1" blocks on it. When I sold it I made sure the guy buying knew everything I did for future reference an he said he's leaving the blocks on it too.
TxFF636
Sep 30, 2013 03:37 PM
Rick13
Jul 30, 2013 03:23 PM
Billie
Mar 4, 2009 08:40 AM
ddsglide
Jan 19, 2009 09:25 PM
jimmything
Sep 27, 2008 07:11 PM
