replace rings when removing cylinders?
Old Nov 8, 2016 | 10:07 AM
RLH3175's Avatar
RLH3175
Originally Posted by langwilliams
I'm going to do this sometime too...maybe next winter...my 99 has less than 20K on it..I want to do the 10:1 piston swap
should you wait to order rings an pistons until you remove the jugs an check for how they're wearing...I don't know how likely it is the cyl wear an will need to be trued.
That is what I did, remove the jugs and mic them and then order the pistons and rings.
Old Nov 8, 2016 | 11:12 AM
800screws's Avatar
800screws
whats an average price of boring/honing cylinders?
Old Nov 8, 2016 | 11:58 AM
RLH3175's Avatar
RLH3175
My 1996 EVO had 72,222 miles on it when I bought it in Aug, 2013, in July 2016 I had 91,850 miles on it, and had developed a base gasket leak/seep on the rear cylinder, I used that as a excuse to change the pistons. You couldn't tell if the engine had ever been apart, but my cylinders showed no ware at all, they miked at the new stock bore dimensions, 3.498". I have a good engine hone, Lisle I think, so I used my drill press and did the honing myself.
Old Nov 8, 2016 | 02:20 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Originally Posted by 800screws
if im removing the cylinders on a stock 80" evo....I should quick hone and replace the rings when not replacing the pistons, right?
You can raise the cylinders and pull the wrist pins and leave the pistons inside the cylinders also. This way you can replace gaskets, etc. and not have to hone or replace rings.
Griz
Old Nov 8, 2016 | 05:17 PM
98hotrodfatboy's Avatar
98hotrodfatboy
The last time I bored I believe it was $160 but that included squaring up the base. I'm pretty sure that $400 cover pistons and rings and bore.
Old Nov 8, 2016 | 05:38 PM
RLH3175's Avatar
RLH3175
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Wiseco K1665 3.498" Bore 10:1 Compression Ratio Domed Forged Piston Kit
GibsonSG
Engine Mechanical Topics
19
Feb 27, 2016 10:00 AM
N-gin
Exhaust System Topics
Sep 9, 2010 09:55 PM
fdh161
Jun 6, 2009 10:31 PM
onebad2
Shovelhead
Mar 17, 2008 09:57 AM
George C
Feb 3, 2006 11:08 AM
