S&S Carb Questions??
Old Feb 2, 2017 | 11:33 AM
Hey Man's Avatar
Hey Man
Originally Posted by flhsport
Got a Super B and want a Super E. Will they switch out easily or do I need new cables and intake? Tires of the spitting and slow response. Love my 89 FLHS!
Cables should be the same. Cable sleeves might be different but they come with the Super E kit. You may also need to change the manifold on the Evo.
Are you sure you have the proper jets in there? I ran a Super B on my Shovelhead for about 30 years and didn't have trouble with spitting or slow response. It might have sneezed now and then but I loved the "B". Have you given any thought to keeping the "B" and getting a SuperBowl for it? It's a new bowl with an accelerator pump in it. Probably be about $350 cheaper than a new Super E kit.
https://www.google.com/search?q=Su8p...HUlKAR8QsAQIPg
http://www.jpcycles.com/product/403-927
Old Feb 2, 2017 | 04:12 PM
aces&8s's Avatar
aces&8s
All my S&S E are easy to set up but some people have problems scratching their butt.
Mine have been problem free and very quick to respond to throttle. The biggest problem I have is the back wheel leaving rubber on the pavement, so go figure. S&S made that carb to preform. I get about 45+ mpg.
Old Feb 3, 2017 | 08:32 PM
flhsport's Avatar
flhsport
I have a .74 jet in it now. Could it be too rich? It seems to be better after it is good and hot but until then it may even cough while cruising at low speeds. And that accelerator bowl requires drilling the main body which sounds like it will require a professional to install, right?
Old Feb 3, 2017 | 08:44 PM
Dr.Hess's Avatar
Dr.Hess
Not too rich, too lean, probably with the low speed jet, if there is one. Sorry, but I last messed with a Super B over 30 years ago.
Dunno what all is involved in the accelerator bowl kit, but I have found very few jobs that "require a professional." It all depends on your skillz, willingness to learn and tool set
Old Feb 3, 2017 | 09:34 PM
ranchodeluxe's Avatar
ranchodeluxe
The Superbowl is kind of a Band-Aid for an outdated unit. The B has too small a venturi, poor circuitry, porous castings, throttle shaft wear, etc.
Once I get a Super G tuned correctly, ( I don't use the E as the way I set them up, the G works on anything but an 883), the accel pump is just barely turned on. In fact, I can shut it off completely and they run quite happily. The pump masks one of the inadequacies of the E or G., that is there are not enough circuits (jets) to cover the entire rpm range without over rich conditions as the fuel circuits overlap. But we still get that lean misfire right off idle (pop), so we throw a bunch of pump at it, that richens it up and masks the lean condition, at the expense of fuel economy.
If you add a third fuel circuit (thunderjet), an adjustable air bleed, and modify the bowl vent you can tune the circuits much more accurately, thus no need for a lot of pump, you go way down on the intermediate jet and down a couple sizes on the main and the fuel economy goes way up. Also allows much better tuning if you have an iffy exhaust setup.
dawroz
Carburetor Related
Aug 15, 2015 04:25 AM
IlDuce
Oct 13, 2010 03:12 PM
manji99
Shovelhead
Jun 25, 2007 10:52 AM
raven28690
Ironhead
Mar 4, 2007 02:40 AM
copper
Sep 27, 2006 07:56 PM
