Just a thought.......has someone fitted progressive springs and not fitted/taken out the spacer? The progressive springs in my FLST are shorter than standard springs and they supply a spacer.
Good question. However with a high mileage and with what we know I'm inclined to suggest chucking them in a bin and replacing with new. Use matched single-rate springs such as Race Tech and get back more fork travel. Set sag at the correct level, bearing in mind most if not all aftermarket springs are shorter than stock and will require apacers.
You have to have the spacer to get the ride height correct.
If you didn't have the spacer on your FLST then your frontend would be 3.25" shorter than it's supposed to be.
That's what I first thought but when I changed mine there was no difference in spring length between the new and old springs.
I guess some springs just last longer than others.
That would have never occurred to me. I've had the same set of Progressive fork springs in my FLSTN for 22 years/200,000 miles and the ride height is just the same as when I installed them. Rides just as well, too.
Springs will collapse over time and not have the same rebound.
If you use the progressive set up you will have to use the spacer provided. They recommend 3" but i went with 3 1/2". love it...
As for the fork oil, you really should be replacing/changing as recommended @ 10k mile intervals. Sludge will build up and the dampers will not work as they should and will clunk. Always check the neck bearing fall away every 10k as well...
