I have to admit that if you have a touring model with the fairly fat 16" tires, and ride conservatively, the difference between Harley Dunlops and anything else won't be as noticeable, but put anything in the power delivery above a stock 103 and push hard, you should really notice the difference. Any model with skinny front tires, especially 21" and above, should have a very noticeable difference in handling with tires that don't have "Harley" on the sidewall. No motorcycle should wiggle on tar strips. I wish it wasn't so, would be nice to have Harley on the sidewall of a real performance tire. Maybe someday. Meanwhile, I won't sacrifice handling just for the name.
Actually it will be very noticeable.
When I had Harley Dunlops on they would slip on every tar snake and bit of road paint that I went over.
When I went to the other tires Dunlop produced (491 Elite II's, Elite 3's, and now American Elite's) all that slipping went away!!
When I was returning home from the last EVO meetup I was in rain for 100 miles and the AMerican Elites didn't slip at all.
The only times I've gotten any of the Elite series of tires to slip was either in the rain when the tire was bald or coming up out of a low water crossing that still has water in it and the algae/slime caused my rear tire to slip when I rolled on the throttle.
I have to admit that if you have a touring model with the fairly fat 16" tires, and ride conservatively, the difference between Harley Dunlops and anything else won't be as noticeable......
It is, honest! The ride quality of something like an Avon is a country mile better.....
Check out the tire chat over on the "Everything Breakout" thread. As a replacement for our HD/Dunlop 240 x 18's, anything but an OEM Harley tire works well.
Our local Dealer annually has a 50% off tire sale. Unless you purchase your OEM replacement tire then, anything but an OEM Harley tire is cheaper too.
The jury is in and the brand that clearly surpasses the OEM Harley/Dunlop brand for price, performance and wear, is the "Anything But".
By most accounts, OEM tires are much like the stock HD front suspension. "Any" alternative seems to be an improvement. The debate is about "how much", not "if".
The only issues I have had with any tire I have had was, 1-wearing too fast. 2- cupping badly. 3-not tracking that great on tar snakes or groved roads.
I never really felt unsafe with any brand including my D402's. The size on mine is MU85B16 or 90B16.
I hadn't had a D402 on the bike since it was new and I had to put one on short notice and the D402 was all my Indy had. I rode it to Canada and it did fine on the trip.
My favorite is the Bias ply Elite III by far. I have pushed the bike in the twities in the Smoky mountains to where it drags in corners and it never slipped or spun on me except when hitting dirt or a ice spot.
If I had a lighter bike or a bike that required a bigger tire I might have had different opinion...
I honestly think that the riding style, road quality, road conditions and load weight affect the performance and outcomes of any tire.
Fortunately we have choices and that is what make it great...
Ride on Homey.
I have D402s on the EVO. Had the bike apart and needed a tire in a hurry.
Like mentioned it was all my Indy had at the time. No they are not my preference by any means.
I have run these tires before and I run them a little on the low side for air pressure. 33-34 frt and back with just me. Learned this on trip a few years back. Does reduce the mileage tho.
Probably run them this year and switch to Commander II. Had them before and really liked them as well, they get good mileage too.
You spin your rear tyres because you have a poor brand!
As for brand, I've been using Avons on my Harleys since the '70s - none nicer! I now have a Cobra front and Storm rear, Venoms for many years prior to them. Why are they so good? Excellent grip in all conditions, including cold and heavy rain - compliant giving improved ride quality and comfort. If you buy them don't foget to check their website, as the routinely recommend higher pressures than stock tyres.
I can certainly agree with ya on the Avons Venoms. Ran them for years on different bikes. I got away from them after 2 friends went with them and the side walls went to cracking in a short time. This was 09 or so. For what ever the reason Avon got a load of complaints on this. They may have fixed this but the Commander II have served me well since.
Guess I could have worded that better, meant as noticeable as the ones with more power and/or skinnier front tires. Biggest difference in tires I've ever experienced was putting Cobras on my 1200C with that skinny 21" front, with the OEM Dunlop, wasn't a mark on the road it didn't try to follow. About the only thing I feel now are bridges with those steel grate sections you can see through, get a slight wiggle on those, but I expect you'd feel that with any tires.
I don't run Avons on my Ural sidecar rig, though. They make sidecar rated tires for it, but wow, they're expensive, and the pusher tire wears out fast no matter what brand, so I run Korean dual purpose tires on that, less than half the cost. You get weird wiggles with a sidecar anyway, and if you break the rear loose, no big deal. Someday I'd like to have a Harley sidecar rig, but I still wouldn't use Avons on it - I'd use car tires!
the michellins are great,been runnin them for the last 5-6 years,almost twice the miles of alot of the major brands..89 flhtc was gettin 9000 on dunlops, 10000 on conti milestones and 15000 on michellins..for the same price as the others!
Avon sidecar tyres are a good deal less than the price of a Cobra over here, so someone between these shores and you is taking the mickey!
I've been running Continental Milestones for several years now. They were a huge improvement over the Dunlops that were on the bike when I bought it ten years ago, so I've stuck with them. After all that I've heard here, both in this thread and others, next time I'm going to try the Avons. Mileage is not really a concern; I'm primarily interested in performance. If the tires ride and handle better, I don't care if they get less miles.
