Softail Wiring Question
Old Feb 1, 2017 | 08:17 PM
14GuineaPig's Avatar
14GuineaPig
I'm guessing a '84 FXST "Shovelouton from his signature
Old Feb 1, 2017 | 09:14 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by sgr60
In the photo below, I feel like there should be a lead going from the battery (or the constant hot post of the solenoid) to the "input" side of the main circuit breaker (the same post that the output from the voltage regulator connects to).
Have you looked at what was on your bike instead of what was on paper?
Does the actual wiring match the diagram or is there a wire connecting the starter and main breaker?
Old Feb 3, 2017 | 04:50 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by 14GuineaPig
I looked at all the wiring diagrams in this manual and the only diagram that doesn't show a 'buss bar' from the battery to the main circuit breaker is the diagram for the 1984 FXST. I guess it could be a mistake that it was omitted in the diagram. I included a diagram from another model just for illustration purposes.
The 84 FXST didn't use the "buss bar"...the main breaker was right beside the battery in a "clip"...with a wire run right to it.
Since it didn't use the buss bar...some "Einstein" took white-out to the schematic...not thinking about how they changed the circuit.
Old Feb 3, 2017 | 04:55 PM
sgr60's Avatar
sgr60
Yup - pretty clear that the diagram was wrong!
Old Feb 4, 2017 | 07:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Another mystery solved....
Old Feb 4, 2017 | 08:04 AM
RANGER73's Avatar
RANGER73
The schematic is correct. the Positive goes to the starter solenoid the start relay switches ground to activate the starter solenoid.
Old Feb 4, 2017 | 10:18 AM
yellowstone kelly's Avatar
yellowstone kelly
I disagree.
Even if the bike was somehow wired up to activate the starter solenoid and the starter motor by having the start relay ground the trigger post of the solenoid, the original post's schematic diagram would then have all the electricity used by the bike flowing from the battery + terminal through the starter solenoid and through the starter relay at all times.
No way.
Edit: I guess once the bike was running, the alternator could provide the power for the bike, but the battery would still have to be recharged through the starter relay and starter solenoid. I don't know of any relays or solenoids that would let it do that successfully.
Old Feb 4, 2017 | 11:44 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by yellowstone kelly
I disagree.
No way.
If the bike was wired like that it would neither start or charge.
Old Feb 4, 2017 | 01:00 PM
Dr.Hess's Avatar
Dr.Hess
So, you're saying that's a shovelhead schematic then? They don't start or charge. Must be it.
Old Feb 4, 2017 | 01:33 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The original schematic posted by the OP (post #3) is drawn incorrectly.
If it were wired as the schematic shows, power would only get to the post on the solenoid and dead end right there.
For the system to operate there must be a connection between the positive battery post and the stud on the main breaker.
