EVO top speed?
Old Feb 5, 2017 | 05:09 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
Default EVO top speed?
I have a '98 Heritage Softail Anniversary Edition Springer with an Evo carbed.
I bought his bike new and only rode it one full season and it's been basically stored with the exception of a "sunny day ride" every once in a while and it has about 9500 miles on it.
Two years ago I took it down to have new tires installed but for the first time ever it didn't want to "rev" without spitting, coughing, etc.
I did the normal stuff (fresh fuel, air cleaner, spark plugs, intake seals, removed and cleaned the carb twice) but still had the same problem.
I pulled the car for the THIRD time and cleaned it again and wouldn't you know, I must have done something right because after that, it ran like new!!!
Anyway, I took it for a ride to "stretch it's legs" and for the first time ever I decided to see what the bike would do on top end speed.
On level ground, it topped out at 90 MPH which is much faster that I need or want it to go but I was wondering if this is close to the average top speed for an EVO.
FWIW, I've owned three other EVO's but I never even bothered to check them.
My Springer has a stock engine, straight Samson fishtails, a dyno-jetted carb, the bike has a windshield and at that time I weighed about 200#'s.
Old Feb 5, 2017 | 05:22 PM
0maha's Avatar
0maha
Don't know if my '90 FHLTC will pull 90MPH, but my FXR certainly would.
So by modern standards, these things are slow. My last Zook would cruise effortlessly at 120MPH and never felt strained or unstable.
Guess I just outgrew that sort of thing.
Old Feb 5, 2017 | 06:16 PM
Yamaharley's Avatar
Yamaharley
I've had my dyna up to 110mph when I had my speedometer still. Started shaking bad will never do it again. I swear though since the speedometer broke and I removed it the bike is a lot faster...
Old Feb 5, 2017 | 06:37 PM
flhchaz's Avatar
flhchaz
I got to 105 mph on my 97 flht before I chickened out. It was still accelerating when I left off the throttle
Old Feb 5, 2017 | 07:28 PM
Prot's Avatar
Prot
I let off of my Heritage at 100 mph while still accelerating.
I wish I had a place to go to see what each of my vehicles top out at and how each of them do in the quarter mile.
Old Feb 5, 2017 | 07:33 PM
Sorg67's Avatar
Sorg67
The only two vehicles I ever topped out were my 1974 Honda 550 Four (95 mph) and my mom's 1977 Gran Torino station wagon 110 mph, a little down hill.
My days of testing top end are long behind me.
Old Feb 5, 2017 | 07:43 PM
Panheader's Avatar
Panheader
Out at sturgis last year did the devils tower loop and one of the straights was clear as far as could see, held it wide open for a long time, held a stable 105 and when wind was less would creep up to 110. A shade faster than my gsxr 1000 in first gear
Old Feb 5, 2017 | 10:13 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I know a lot guys are afraid of the death wobble, which on my bike kicks in around 115 mph. Just like in the movie with the Aussie that wanted to run the salt flats. You can push through it if you want and yea it gets a little nerve racking but you can do it. The most i had the nerve to do was 136 mph. On a heavey bike its not the most stable.. I have been upwards of that though when I was younger and cruising on rice grinder.... It is a thrill... Exhilarating.....
Old Feb 6, 2017 | 08:26 AM
RLH3175's Avatar
RLH3175
My 1996 EVO will go 100 +, my 1998 non-stock, Suzuki Bandit would 140, in the 1/4 mile at 9.7 seconds, would top out at about 185 with stock gearing.
Old Feb 6, 2017 | 08:40 AM
pie plate's Avatar
pie plate
Bikes, dressers, have, it is true, fairly small frontal areas aerodynamically - but they also have really bad drag ratios and eddies - and fairly short length to area ratios. Minor variations in lay-out can make for large changes in absolute drag at air-speeds like 90 +
Nevertheless I'd expect to see just about any Harley bust a full ton. Guys have done that on a 45... But like you say, 90 is fasternyawannago... Me too.
