slow cranking
Old Feb 7, 2017 | 09:34 AM
WVICEMAN's Avatar
WVICEMAN
Default slow cranking
Morning all, I bought a 1985 FLTC and since I've owned it it's turns over very slow when I start it. I thought it was the battery as I didn't know the age so I bought a new battery and still the same. I took the new battery back and had it load tested and it was good so I put it on the charger and fully charged it with the same results. I bought a new starter but have yet to replace it but am thinking it probably is just corroded at the ground points and need a good cleaning. Any thoughts?
Old Feb 7, 2017 | 11:12 AM
Prot's Avatar
Prot
Replace your cables. Sumax makes very good heavy duty cables.
Take a look at some of the stickies also.
Old Feb 7, 2017 | 11:42 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Has the motor been built? Does it have higher than normal compression....? Cause that'll do it.... The thing about an older used bike is that you'll never get all the info on it as to what's been changed or upgraded... Do a compression test....
Old Feb 7, 2017 | 02:10 PM
RLH3175's Avatar
RLH3175
Adding a second relay to fix the dreaded click
Mine was slow to start and I added the relay and have not had a problem since.
Old Feb 7, 2017 | 03:16 PM
Alienwulf's Avatar
Alienwulf
Had that problem was the small wiring running to and from the start button. Ended up replacing it but until I got to it I installed a relay button on the started and bypassed it all worked great. If I ever have a low battery it will help crank it over.
Amazon Amazon
Old Feb 7, 2017 | 04:09 PM
glidein wide's Avatar
glidein wide
Not to high jack here... I was thinking of doing this also but what if one relay craps out, it still won't crank? Is that correct ? Curious.. don't have a problem, just preventative maintenance I think.
Old Feb 7, 2017 | 04:15 PM
Prot's Avatar
Prot
It might also be worth cleaning the ignition switch.
Old Feb 7, 2017 | 04:46 PM
98hotrodfatboy
Then Don't Kevin...... LOL...... How you doing buddy... You gonna meet up this year?
Old Feb 7, 2017 | 05:43 PM
glidein wide
I probably won't know until that week, but I would really like to go.
Old Feb 8, 2017 | 07:58 AM
carlgrover's Avatar
carlgrover
This might be a stupid question but what motor is in that bike? I believe some of the early 1985s were shovels, maybe shovel bottom end and EVO top end. Anyway, if it's a shovel, turning over slowly is fairly normal. My shovel groans and struggles but still comes to life.
carl
