slow cranking
Old Feb 8, 2017 | 11:53 AM
RLH3175's Avatar
RLH3175
If one of the relays fail then it would not engage the starter.
All the electrical problems that I have had, starting and turn signals, was because of poor grounding, the relay fixed the starting issue, for the other grounding issue, I took about 6 ft of heavy gauge wire and connected to the batter ground point on the frame, then to the front head, and then to the medal brackets that hold the fairing on, and that fixed the turn signals.
Old Feb 10, 2017 | 08:24 AM
WVICEMAN's Avatar
WVICEMAN
Originally Posted by carlgrover
This might be a stupid question but what motor is in that bike? I believe some of the early 1985s were shovels, maybe shovel bottom end and EVO top end. Anyway, if it's a shovel, turning over slowly is fairly normal. My shovel groans and struggles but still comes to life.
carl
Yea she's a shovelution and she always starts just turns over slowly. I'll clean all the connections and put in a second relay and see if that helps before I replace the starter.
Old Feb 10, 2017 | 10:45 AM
carlgrover's Avatar
carlgrover
If you decide to replace the starter and IF you decide to go with one of those ALL-***** deals instead of a straight replacement you will have to upgrade all your cables and I think you'll need a bigger battery to get the benefit out of the starter. I had the starter to my shovel in my hand and was thinking of rebuilding it/tearing it apart/cleaning/ect. but took it to a bike shop to ask them what to do. He said don't take that thing apart! and it isn't really serviceable.
Just throwing it out there in case it helps.
carl
Old Feb 10, 2017 | 11:01 AM
billib1954's Avatar
billib1954
Put a pushbutton on your starter solenoid. That provides full battery power to starter. What oil is in the engine? Mine cranks slowly in cool/cold weather due to straight 50 wt.
Old Feb 12, 2017 | 04:35 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The bike is a 1985 model year....it has a different starter configuration than the `89 and later bikes.
Streetrunner
Apr 9, 2024 12:08 AM
Javieret
EVO
22
Mar 4, 2019 08:13 AM
Nitro Joe
Electrical/Lighting/Alarm
May 4, 2018 04:25 AM
Piper54
EVO
Jul 19, 2010 08:22 PM
'75 Chop
Ironhead
23
Mar 2, 2009 05:28 AM
