Starter Hesitation
Old Aug 30, 2017 | 05:12 PM
Streetrunner's Avatar
Streetrunner
Default Starter Hesitation
2010 EG Classic. When I hit the starter there is a hesitation or pause then it starts right up.
This has also happened in the past to this bike. May of 2016 it was doing the same thing so I bought a new Deka battery ETX30L, 400cca and 26 AH. Problem solved until last week. I have had this battery on a tender this week voltage measures 12.82v with the bike off and 14.1 when running. But it does take a few second to get there. I also did a start test and it dropped down to 10.5v.
My Harley battery only lasted two years this Deka is 1 1/2 years old but has been through two seasons. So the question is does my bike just go through batteries or do I have a starter problem. When I replaced the HD battery my dealer said the battery tested good but as soon as I put the fresh Deka in it started quick up until now.
Any thoughts?
Old Aug 30, 2017 | 05:17 PM
Captain Itch's Avatar
Captain Itch
Sponsor
I usually get a 3 - 4 years from a battery .. Start checking connections on starter and battery..
__________________
www.Captain-Itch.com
Old Aug 30, 2017 | 05:21 PM
Veekness's Avatar
Veekness
There have been other threads on this subject. ..I believe the consensus was...no biggie. ..but I could be wrong
Old Aug 30, 2017 | 05:27 PM
jeffreydsilver's Avatar
jeffreydsilver
+1 on this! Check the connections at both ends of both cables! What do you mean by "it does take a few second to get there"? I'd be interested to know what the battery reads, without the tender, AFTER you crank the bike without starting it. Sort of a home grown load test! 12.82 is a good reading UNLESS your just reading a surface charge because the tender had been on it. I wouldn't eliminate the possibility of needing a new battery. Check for a date code on the battery to see how old it really is.
Old Aug 30, 2017 | 06:11 PM
Streetrunner
Those readings are without the tender and after about a hal hour ride today
Old Aug 30, 2017 | 06:40 PM
Streetrunner
Problem solved. You guys were right. It was a minutely loose positive connection on the battery.
Thanks.
Old Aug 30, 2017 | 11:17 PM
wscott's Avatar
wscott
Any thoughts?
Old Aug 31, 2017 | 03:19 AM
TriDan's Avatar
TriDan
I've had three bikes. On two of them there was an initial WHIR (pause) WHIR-start.
On one that pause wasn't there.
I've had this one on a tender pretty much every night since I bought a new battery thinking the same thing, the battery was thinking about starting to decline.
Nope, that pause is every time I start.
I'm doing the ignore it until it causes a fault somewhere thing.
Old Aug 31, 2017 | 07:45 AM
Just Me's Avatar
Just Me
Every Harley that I have owned has done it. Why in hell does Harley gear the starter up so high? No need for it but they figuring we will buy more batteries and starters that way.
Old Aug 31, 2017 | 01:07 PM
btsom's Avatar
btsom
It seems that just like the old style compensators, the 96 ci engines are also too much for the starters. A year of "peppy" starts is about all i get. This is probably why the 103s have ACRs. One of these days I will disassemble the starter solenoid and check for carbon tracking that may also be adding resistance to the start circuit. (2008 Road King, 87,000 miles)
