Jet Recommendation
Old Dec 4, 2021 | 01:31 AM
Kenneth Wise's Avatar
Kenneth Wise
Originally Posted by mike131
Nice bike, idled down way to low, but thats just me
Thanks for the compliment and yes I totally agree about the idle being low. I only did this for making a cool "potato potato" sound for entertainment purposes only.
I typically run my idle right around 900 RPM's as the Evolution oiling system really needs it. The EFI bikes can't do that due to their electronics needing all of that 13v to keep it running right LOL
I just did a 50 mile oil change and wanted to see how well balanced the flywheel assembly was and also see how low it could go yet still ramp up on throttle.
Although I didn't show this in this video im glad i did that because i ended up having to put a. 060" shim (washer) underneath the slide needle to get rid of a nagging flat spot it had between the two circuits. Seems to have eliminated that problem.
Kenny Wise
Old Sep 27, 2023 | 09:18 PM
Samurai3301's Avatar
Samurai3301
Stage I
Default Cam jet
I’m rockn’ a super e carb with an andrews e27 and screaming eagle 2 to 1. She runs really good. But idles high. The rear plug is a light shade of white but the front plug is black.. any suggestions?
Old Sep 27, 2023 | 09:24 PM
M Oclaf's Avatar
M Oclaf
Old Sep 27, 2023 | 09:25 PM
Tommy C's Avatar
Tommy C
Check for an air leak. You may have a leaky intake manifold seal.
Old Sep 28, 2023 | 04:13 AM
Kenneth Wise
Yep, same thing I was going to recommend. Sounds like you have an intake manifold leak.
I only use Viton seals on my bikes, theyll last forever, more pliable and wont deteriorate like Buna ones will. They can also take a LOT more heat.
To see if you have a leak in that area hit it with some brake cleaner spray. Youll find out really quick if it's got a leak.
Kenny
Old Sep 28, 2023 | 08:04 AM
IBDAGRIZ's Avatar
IBDAGRIZ
Originally Posted by Kenneth Wise
Hello fellow forum folks..
I'm currently running a 4 5/8" stroker, CV40 with a homemade made incognito Stage 1 aibox with a velocity stack and Screamin' Eagle slip ons.
My jetting is a whopping 50 pilot and 195 Main. After my engine is broken in im likely to to go north of a 200 Main. Time will tell..
I'm running a CV 44MM carb with 48 / 220 jetting on my 96" stroker. A/F gauge is right on 14.0 - 14.6 running 75 on freeway at 2k revs.
Griz
Old Sep 28, 2023 | 01:53 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Griz
Should have been 2.5k revs. 6 speed on my FLHTCU.
Griz
MIKE93SVT
EVO
16
Jun 26, 2016 11:13 PM
bikerlaw
EVO
17
Sep 26, 2011 04:53 PM
Lincoln33
Sep 6, 2011 11:47 PM
AGB
EVO
Jun 12, 2009 11:02 AM
lowriderrob
Exhaust System Topics
Feb 7, 2009 07:04 AM
