4 speed inner primary bearing
Old Mar 10, 2017 | 09:44 PM
Wyatt MacGregor's Avatar
Wyatt MacGregor
Stage III
Default 4 speed inner primary bearing
Hey guys, I have a 85 dyna wide glide with a 4 speed, Im tying to get the inner primary bearing race off the tapered shaft and it is being a POS . I've heated it up and wacked it and nothing is moving so I think I am going to have to cut it off. no once I get that off do you guys recommend the aftermarket sealed bearing? I've read that some don't work with the tapered shaft, how does a guy know. Help please, first project bike.
Old Mar 10, 2017 | 10:15 PM
johnjzjz's Avatar
johnjzjz
with the sealed bearing go for the usa - japon - german SKF - sort of unit - in my shop we carefully remove the plastic shield clean it complete and dry the bearing, then use a real wheel bearing grease - i like the 2 guys garage green grease until you use it no one can explain why ) do it every 5000 miles on a you own the bike , its not a biggy in the off season
Old Mar 11, 2017 | 06:28 AM
glidein wide's Avatar
glidein wide
First.. welcome from Connecticut.
Second.. your bike is not a Dyna, they came out in 92/93 ish..
Third.. John is one of the smartest guys here on the forums..
That being said, here is another option.. the race on the shaft is removed with a special tool that is also used to reinstall the new one (or old one). I have the same tranny and installed the Oem style bearing in the inner primary case and new seal, and a new race on the shaft.
Do you have a service manual? You should have one, and they have a pic of tools in the manual...
All has been well with mine and if I need to dig in there for what ever reasons, I would just replace the seal while I'm there.
What are you doing to the tranny? Why removing the race? Using a torch there will ruin the inner seal/o ring... hope this helps.. GW
Old Mar 11, 2017 | 02:17 PM
Wyatt MacGregor
Stage III
I had to replace the main seal on the tranny then I noticed that my inner race has a ring cut into it so I will replace that as well, I barrowed that tool from a buddy but we broke it. ( she is on good). And to order a new one in Canada is 150$ so I can just cut it off for a 3$ blade lol.
Old Mar 11, 2017 | 02:28 PM
TwiZted Biker's Avatar
TwiZted Biker
I've had a few of them that had to be split with a dremal and small chisel to come off the shaft, rare but does happen. Go the sealed bearing and follow John's advice it's solid as you can get. Next on the problem ones I use a fine grit emery paper to polish the shaft and dry fit the new bearing, if you have to pound it the shafts got issues back to the emery paper. Use a little anti seize on the shaft when you do reinstall, helps not having a repeat of this later.
Old Mar 12, 2017 | 02:30 PM
RedHogz's Avatar
RedHogz
Try and use the press installer tool to put the race back on. I got lucky and tapped it on with a dead-blow hammer and section of 1" steel pipe. I know, I know that's not the best way 'cause you can damage the bearings, but i was willing to take that chance in lieu of paying a few hundred bucks for the removal\reinstall tool from J&P. That being said, some wrenches have used Loctite stud and sleeve retainer to make damn sure that race don't spin on the shaft. Mine was very tight going on so there shouldn't be an issue.
Old Mar 13, 2017 | 06:26 AM
Scootertrash60's Avatar
Scootertrash60
Not to hijack this thread, but are some of you saying you can remove the OEM inner race from the mainshaft and replace the inner primary bearing with one that has an ID that matches the mainshaft, eliminating the OEM style inner bearing race?
If this is the case what is the bearing number/OD-ID?
Old Mar 26, 2017 | 07:20 AM
glidein wide
I don't have those numbers for you,the reason why I chose to stick with the Oem style is because I couldn't understand how can I possibly slide on the inner primary over the main shaft with a sealed bearing pressed into the inner primary, the ID can't be loose on the shaft !?!?
If you install the sealed bearing on the shaft snug like the Oem race, how could I possibly slide the inner primary over it and NOT have the OD fit into the primary loose ? So ONLY the Oem style made sense to me and all is well, would be nice if John or someone else chimes in and explains details ..
Old Mar 26, 2017 | 09:18 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
What's the difference between having the inner part of a sealed bearing fitting "loose" on the transmission main shaft and having the OEM primary bearing fitting "loose" on the inner race.
Baker makes the IPB and they know a hell of a lot about Harley transmissions.
I put one in my bike and really like the fact that the race will NEVER slip into the transmission main seal.
Old Mar 26, 2017 | 10:00 AM
glidein wide
Well I don't know the tolerance of the inner part of the sealed bearing on the shaft and what type of wear could take place on the shaft. It must slip some when spinning I would think, instead of just the roller themselves. I've never had my race walk inwards before but I know others have. Oem style.... the only friction point is where it's supposed to be... bearing rollers on race.
I'm not saying sealed one is a bad idea to swap to,I'm saying that I don't understand the reason or the payoff, having not played with that style there.
Now I have sealed bearing pressed into the front wheels on my riding lawnmower, they slip over the axle shaft and I know the inner part of the bearing still slips on the axle shaft wearing it down. That's my thinking of it, that's all..
