not happy when wet
Old Apr 26, 2017 | 12:22 PM
mr-stabby's Avatar
mr-stabby
Default not happy when wet
having probs with fatty in the wet. fatty is a 98 fxd convertible and i came into ownership 4 months ago ,,, anyway were were out for a run last friday and we got a soaking fatty dropped to one cylinder and died one i got too the side of the road , she did it again about 10 miles later but i just kept going and she cleared up and went on as normal after 3 miles of being a cement mixer ,, spent the night at a camp sight and it rained all night ,next morning all she wanted too do was spit and flame out the exhausts so had to get her recovered home ,, got her home off the recovery truck and she started up all happy as larry ..
any thought whats going on I'm thinking the coils getting wet and shorting .
any thoughts folks
Old Apr 26, 2017 | 12:30 PM
Donnylee's Avatar
Donnylee
Maybe some bad plug wires?
Old Apr 26, 2017 | 12:31 PM
Pinetop's Avatar
Pinetop
Default So many causes
This could be related to many problems. I have found rain getting into bad connections, to battery terminals or power wires and lastly the rubbed wire exposed to rain water, all as likely as the other on our bikes unless you change wiring harness which I eventually did.
Old Apr 26, 2017 | 02:09 PM
Tom84FXST's Avatar
Tom84FXST
This would be my first suspect since it runs fine as soon as it drys off.
Old Apr 26, 2017 | 05:04 PM
Yankee Dog's Avatar
Yankee Dog
Yes, I would get a squirt bottle and start "shootin" looking to reproduce the issue while in the comfort of your garage and not out in the woods or on the side of the road.
My first thought is plug wires also. If not plug wires, then look for a crack in the coil case or the wires at or around your coil. YD
Old Apr 26, 2017 | 08:47 PM
spanky02's Avatar
spanky02
I chased these same issues with my 96 fxd. Replace wires and coil twice. My issue ended up being the ignition pickup in the cone. Replaced that with a dynatek and all was well.
Old Apr 26, 2017 | 08:57 PM
TwiZted Biker's Avatar
TwiZted Biker
At an idle grab the plug wires , you'll know quick enough if they are bad. I'd just change them out they are old enough.
Old Apr 27, 2017 | 03:47 AM
mr-stabby's Avatar
mr-stabby
bike has taylor leads but not sure old they are ,, bought some silicone grease to see is that helps
then try leads of swap out the coil
bluharley
EVO
14
Jul 14, 2013 11:38 PM
shagster
Sep 26, 2012 12:28 PM
Fastrider124
Mar 3, 2012 01:46 PM
elmo771
Jul 25, 2010 02:32 PM
TOMMAY
Apr 3, 2007 01:58 PM
