Lg engine head breathers?
Old May 1, 2017 | 09:17 AM
aces&8s's Avatar
aces&8s
Default Lg engine head breathers?
I had a thought which is rare.
Lg cube engines can make a lot of crankcase pressure and need good venting specially at high RPM. Head breather's normally piped to the carb would be pulling extra pressure thru carb vacuum.
NOT connecting them thru carb would loose that extra vacuum to relieve pressure. Thoughts?
Old May 6, 2017 | 05:15 AM
grbrown's Avatar
grbrown
I believe that some highly tuned engines have been built using both crankcase and head breathing systems, presumably to get the best of both worlds.
Old May 6, 2017 | 07:12 AM
1997bagger's Avatar
1997bagger
Run them to the ground, I have ran mine before without any hose on the fittings and doesn't leak a drop, can hear it huffing at a idle but as long as the engine is sound, won't put a drop of oil on the ground.
HD-1995
Carburetor Related
Nov 5, 2015 10:03 PM
CaptnAl
Nov 20, 2012 05:41 AM
Morgan's
Exhaust System Topics
Oct 14, 2010 05:54 AM
solitaryman54
Ironhead
May 17, 2007 11:57 AM
mchaous
Oct 31, 2005 06:16 PM
