CV carb running lean?
Old May 13, 2017 | 12:20 PM
splittie65's Avatar
splittie65
Default CV carb running lean?
I replaced the carb on my 1995 Fatboy, back to the standard CV carb. Standard engine with a mild cam and a Fatshot Supertrapp exhaust.
I had a previous thread on this a while back, so if you want to read that: https://www.hdforums.com/forum/evo-c...arburetor.html
I replaced the maifold rubbers etc...
I fitted 48/195 jets, as per Spanners suggestion as a starting point, and replaced all the gaskets / seals / needle etc. These are probably slightly on the large size, so I was expecting the sparkplugs to be good to black.
I have a Yost idle mixture screw, and they recommend turning it out 2 1/2 turns as a starting point for my bike.
The spark plug comes out white.
I adjusted the mixture screw out a further half turn with no effect.....and a further half turn with no effect.
I would have thought the idle jet is unlikely to be blocked, however I will check.
Are there any airways or anything else i should check while I have the carb off again?
Any other suggestions?
Old May 13, 2017 | 01:48 PM
splittie65's Avatar
splittie65
Old May 13, 2017 | 06:07 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Spray some carb cleaner around your intake to make sure it's sealed correctly.
Old May 14, 2017 | 07:42 AM
splittie65's Avatar
splittie65
Thanks for your suggestion Texas.......
I checked the intake for leaks....to no avail.
Took the carb off again, and even though the carb had been cleaned and the jets replaced, the idle jet was blocked!
Working OK now.
BobbyH83
Nov 26, 2017 08:31 AM
FrankCaputo
Nov 23, 2015 07:44 PM
Big Pap
Exhaust System Topics
Dec 1, 2012 10:49 PM
radio915
Classic
Oct 30, 2007 09:06 PM
kkeesy
Jul 8, 2007 07:59 AM
