Occasionally leaking gas
Old May 30, 2017 | 10:40 PM
BT80's Avatar
BT80
Lots of great advice here. I recently performed the same procedure on my carb using these instructions:
https://cv-performance.com/harley-fu...ow-replacement
Worked like a charm.
Old Jun 11, 2017 | 02:04 AM
Big Panda's Avatar
Big Panda
Well it wasn't as hard as I thought it was going to be. Everything went exactly as the links you all provided said it would. Got the elbow out and the new one pressed in with a bench vice. The carb leaked a little at first but that may have been residue because I rode for 7 hours today stopping several times and it never had any gas leaking out when I returned to it. Thanks everyone! New elbow pressed into place
Old Jun 11, 2017 | 12:21 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Glad you got it going..
I love a happy ending!!!!
Old Jun 12, 2017 | 09:53 PM
Big Panda's Avatar
Big Panda
Well, came out this morning to this... guess it isn't fixed. So where to go from here? Does the float need an adjustment?
Attached Thumbnails Occasionally leaking gas-51890318856__a5cdb8b5-739e-4286-95f0-188f9f43d198.jpg.jpeg
Old Jun 12, 2017 | 10:14 PM
Owtlaw's Avatar
Owtlaw
Probably. Was the petcock turned off?
Old Jun 12, 2017 | 10:16 PM
Big Panda's Avatar
Big Panda
No pet **** was on. It never leaks when petcock is turned off. Will it always leak if I leave the petcock on? I thought that was the whole idea of the float to prevent it from leaking?
Old Jun 12, 2017 | 10:23 PM
Beemervet's Avatar
Beemervet
It will if the float needs adjustment. I always turn off the petcock. (old habit)
Old Jun 12, 2017 | 10:49 PM
texashillcountry
Dirt don't hurt
The whole idea of a float is to maintain the correct amount of fuel in the float bowl.
It won't prevent leaks.
First thing to check is to see if the fuel came out of the overflow tube.
If it did I recommend cleaning the needle seat with polishing compound and q-tips.
Old Jun 12, 2017 | 11:08 PM
Big Panda's Avatar
Big Panda
It did come out the overflow tube and I have just gotten finished taking it all apart and cleaning everything, so everything is clean.
Old Jun 13, 2017 | 07:41 AM
raymint's Avatar
raymint
the float can be trickey but as a starting point if you are leaking from the overflow adjust the tab closer to the needle and seat, the need to clean the seat is if any thing is stopping the neddle from shuting the gas flowing into the carb the adjustment of the float wont matter good luck.
