Drive belt rubbing sprocket
Old Mar 24, 2018 | 05:40 AM
grbrown's Avatar
grbrown
I had a pulley ring come off some years ago and messed about with it, but eventually gave up and bought a secondhand replacement. If anything the belt normally rubs against the outer fixed flange, not the rivetted one, which is why the design is normally fine. If your belt is rubbing against the wrong flange then check wheel alignment, which can change how the belt tracks on the pulleys.
Old Mar 24, 2018 | 07:47 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Old Mar 25, 2018 | 10:52 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Originally Posted by Pitpig
No pulley bolts to torque. It has a Isolation drive. Pulley is aluminum and the ring is steel so no go on welding.
"Friction" welding.
Old Mar 26, 2018 | 04:27 PM
nordhaven's Avatar
nordhaven
Default Belt issue
Now I'm certainly no expert so I hope you excuse my ignorance if this sounds kinda off, but if rear wheel is aligned using the guide tool or one home made, as in the FSM, then is it not possible the belt misalignment could be due to the swing arm out of alignment? As in aligned with top dogbone alignment adj between jugs just under the tank?
Old Mar 26, 2018 | 04:41 PM
grbrown's Avatar
grbrown
Wink
The swingarm is attached to the rear of the trans/engine unit, which when doing a complete vehicle alignment is done first, then the rear wheel is adjusted in the swingarm relative to the front wheel. The swingarm itself cannot alter the belt alignment, as the s/a and tranny are united as one. Hope that makes sense!
Old Mar 26, 2018 | 04:44 PM
nordhaven's Avatar
nordhaven
I see, thanks for the education! Makes complete sense.
NoRegerts
Jun 4, 2013 10:36 AM
jokenroll
EVO
Nov 3, 2012 12:50 AM
WRAITH
Nov 1, 2007 12:06 PM
bluedog
Feb 23, 2006 12:15 PM
HDF Tech
Feb 4, 2006 08:41 PM
