I want to vent my crank case head breather better than my hose running out the back. Looking for suggestions on a better way or a kit to relieve crank pressure.
Is it going to atmosphere now? If so all you can do is try to hide the piping a little better. The best look is the steel braided lines with a filter on the end tucked up under the frame...
Aces, not sure if you're looking to see it or hide it. If you're looking to hide it this is what I did. I ran the 3/8" line between the cylinders to a UP-122 Uni Breather filter. It has a zip tie loop built in. Secured it behind the horn tucked up high. You can't see it completely hidden. Used standard black 3/8" hose as I didn't want to see that either. You could hide this one anywhere it's small. I was going to put a T in the center and put a catch can or on off drain to drain any oil that gets in there but I don't think I need to so I left it.
Is this an "If it ain't broke fix it till it is" thing????
Yes its going to atmosphere now. Thanks
Originally Posted by Prot
Are your umbrella valves in decent shape?
It's my new S&S 111. I am trying to relieve crank pressure. Thinking of 2 breathers ,one for each head.
Originally Posted by Albe
I know it's a TC but after getting blowby on my oil tank and rear header pipe,
I did this.
Thanks, your bike looks great.
Thanks KP, appreciate that.
I think aces&8's is taking about his new motor. The V111 he just put in....
Yes, the new 111
Nope.. There is a lot of crank pressure. Had my oil cap off and cranked it and yea a lot of built up pressure that just one small hose seems to small to relieve the unneeded back pressure.
