Help installing Pingel
Old Jun 7, 2017 | 04:12 PM
rainsong's Avatar
rainsong
Default Help installing Pingel
I've searched around and haven't been able to find a definitive answer on this...
Trying to replace a stock petcock on my Fatboy with the Pingel I bought. How do I plug the vacuum line?
Pingel instructions say to plug it at the T-connection. Which if I'm understanding correctly is underneath and between the two tanks. Do I need to remove one of the tanks to get under there?
Or do I plug it at the back of the carb? And if so, do I need to remove the right tank to get back there?
Old Jun 7, 2017 | 05:50 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
These instructions presume your bike is stock.
Pull off the right tank.
Remove rubber hose from top of carb to include the t junction, the piece of hose that went to your old petcock, and the VOES.
Get a new rubber line and run it from carb to VOES.
Don't cap anything.
Old Jun 7, 2017 | 06:34 PM
rainsong's Avatar
rainsong
Appreciate it!
Old Jun 8, 2017 | 11:34 AM
rainsong's Avatar
rainsong
Always a complication...
Apparently I overtightened the acorn nut on my tank console, so now it won't come off...which means I can't get the right tank off. I'll probably have to Dremel the nut off, but it's not sounding like dealers have a replacement screw & nut in stock here.
And I've got an overnight trip I'm supposed to leave on tomorrow morning.
If I cap the line with a screw or something would that work until I can get the tank off and follow the procedure mentioned by TXHill? Or am I asking for trouble by doing that?
Old Jun 8, 2017 | 11:38 AM
rainsong's Avatar
rainsong
Or (just thought of this), could I do it by removing the air cleaner and/or carb instead of removing the tank?
texashillcountry
Dirt don't hurt
If you put a screw into the hose then make sure it's over sized and secure the hose so that it doesn't bounce around.
Andy Tucker
Powdercoat & Paint
Jun 8, 2019 06:20 PM
bkbroiler
Carburetor Related
15
Apr 9, 2019 06:07 AM
Skin7
Aug 16, 2018 04:02 PM
trozenhorse
Nov 21, 2010 09:33 AM
phantomroadking
Exhaust System Topics
Oct 11, 2006 02:34 PM
