better acceleration
Old Jun 15, 2017 | 09:11 PM
  #41
1997bagger's Avatar
1997bagger
Wrong, it was for a Shovel
Old Jun 16, 2017 | 05:43 AM
  #42
98hotrodfatboy's Avatar
98hotrodfatboy
So you're running 24/37-32/70???
If so, that is a 3.37. More than optimal for performance. If that's not good enough than you really need to look at a bigger motor....
Old Jun 16, 2017 | 07:22 PM
  #43
bentparts's Avatar
bentparts
Ordered one from Baker ( 23 T ) when it comes in the swap should be relatively easy and I think it's worth a try. I agree with everyone's assessment that a bigger engine is most likely the only thing that will satisfy fully, but it's just not in the cards right now. I'll check back in once I've swapped and tested it out.
Old Jun 16, 2017 | 07:24 PM
  #44
bentparts's Avatar
bentparts
Your probably right, no replacement for displacement.
Old Jun 17, 2017 | 06:23 AM
  #45
98hotrodfatboy
Let us know what the rpm is at 70 mph with that 23 gear @ 3.51 ratio...
Old Jun 17, 2017 | 03:59 PM
  #46
br549A1's Avatar
br549A1
Ok you guys got me interested in this. I found a kit that comes with a 21T comp and new chain for about $125. Seems cheap, anyone running a 21T with the 36T clutch?
Old Jun 18, 2017 | 07:39 AM
  #47
1997bagger's Avatar
1997bagger
Been a 21t Screamin Eagle part around for a while, calculate your gear ratio before jumping on it, 350-360 final ratio gets some R's down the road
Old Jun 18, 2017 | 08:03 AM
  #48
bentparts's Avatar
bentparts
Curious, did you find that at a HD dealer?
Old Jun 18, 2017 | 08:12 AM
  #49
98hotrodfatboy
I guess it wouldn't hurt to go to a 22 or 21. According to my 77 fsm the fx went as low as a 3.73 and the fl's 3.90. Just gotta watch the highway speeds....
Old Jun 18, 2017 | 08:23 AM
  #50
br549A1's Avatar
br549A1
http://www.dragspecialties.com/produ...umber=11200011
