CV Needle Question
Old Jun 21, 2017 | 04:41 PM
timsmcm's Avatar
timsmcm
I love my cv carb. Easy to work on. Set it and forget it.
Old Jun 21, 2017 | 05:22 PM
89FL's Avatar
89FL
Originally Posted by timsmcm
Order cv performance velocity needle and 46 idle 180 main. You will like it if you have a stock motor with pipes and air cleaner.
I have the CV performance velocity needle, just haven't installed it yet.
I was going with 46/180 set up next. Might as well put the new needle in.
Old Jun 21, 2017 | 05:37 PM
Beemervet's Avatar
Beemervet
Originally Posted by misput
Which carb will give you the best potato potato sound at low idle?
Any carb attached to a Knuckle, Pan, or Shovelhead.
Old Jun 21, 2017 | 08:31 PM
timsmcm's Avatar
timsmcm
You will like it. Start 2 to 2 1/2 out from lightly seated on the low speed screw.
Old Jun 21, 2017 | 09:10 PM
misput's Avatar
misput
Old Jun 23, 2017 | 09:42 AM
timsmcm's Avatar
timsmcm
What exhaust and cleaner do you have? If you have a little blurb blurb once in a while at idle get a 45 idle jet .
Old Jun 23, 2017 | 10:39 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Looks ok. You don't want to idle a motor that low.. it's not good for the crank pin... And if you noticed every time he went to throttle it up he had to feather the throttle.... And just so you know it's in the cam.... And not the carburator.....
Also If you know this guy tell him to tighten up the rear pipe, it's quite loose.....
Old Jun 23, 2017 | 12:27 PM
misput's Avatar
misput
To heck with the crank pin and the oil pressure, in normal riding the engine doesn't spend that much time at idle and I would kill for that sound. It's an 80 cubic inch with 10.5:1 heads (ported and polished) Super "E" carb and an S&S 561 cam. In the comments under the video he said he tightened the pipe.
Question: I have a 2000 sport 883/1200 with #25648-91 se cams and se slipons, lollypop baffles, nice diy A/C, 6800 RPM Ing. module and it sounds pretty good but not like I would like. Got any suggestions besides, if it ain't broke don't fix it
PS: it has the stock 883 pulley's and will do 80 in 3rd gear like a scalded dog!
Old Jun 23, 2017 | 03:18 PM
89FL's Avatar
89FL
Samson slip-ons and a mesh bug eye air cleaner. While I am waiting for the new main jets to arrive, I put the 46 idle jet in and took a ride. I think I found the sweet spot. It ran like its old self again only better, thanks to the new carb.
Old Jun 23, 2017 | 03:24 PM
timsmcm's Avatar
timsmcm
Great, that velocity needle is gona work for you also.
Sportster330
Jun 22, 2024 03:02 PM
Skiprrrdog
EVO
May 17, 2016 06:00 AM
zakaria777
Carburetor Related
Oct 9, 2015 07:18 PM
gilmour68
Aug 19, 2012 04:47 PM
NutterFLH
EVO
Feb 18, 2011 02:28 PM
