1984 FXRT Primary Oil Line Question
Old Jul 4, 2017 | 02:10 AM
jamesandthejet's Avatar
jamesandthejet
1st Gear
Default 1984 FXRT Primary Oil Line Question
Hello Everyone.
I recently purchased an 1984 FXRT with a pulled cylinder stud. In addition I purchases a 1990 EVO motor to replace the 1984 motor. I swapped out the motors and was running the oil lines and started to discover some issues I can't seem to find a good answer on.
Please see below diagram of oil line routing on the early model 1984 FXRT.
There are two oil lines that go into the primary. One is a "T'ed" off line from the oil pump going up the the oil vent tube. The other is routed to the engine case separate from the engine case breather vent. . The issue I am running into is the 1990 EVO motor does not have that oil line attachment on the engine case as the original motor cases had.
I have done some reading about isolating the primary. I believe I could do this rather easy but reviews on the longevity of the fix are mixed. If I did do this and needed the vent the primary how would you do this. In addition since I have a dry clutch in there if I fill the oil just to the bottom of the clutch basket will it be okay or will my clutch go bad.
The other question I had was if I wanted to keep the oil system that is in place. Instead of running the line back to the engine cases could I run the line and "T" it off to an existing oil line? Perhaps the feed line from the oil pump into the oil filter?
Thanks in advance for you assistance.
statcar
Ironhead
Apr 14, 2025 05:46 AM
jamesandthejet
EVO
13
May 15, 2018 09:06 PM
LostInNM
Shovelhead
Oct 14, 2015 03:23 PM
Cupo
EVO
13
Jul 12, 2011 09:30 PM
mrbikeuk
Oil Archive (no new posts)
Oct 4, 2008 05:00 PM
