1993 turn signal issues, need help
Old Jul 30, 2017 | 08:57 PM
hames93fxr's Avatar
hames93fxr
Stage IV
Default 1993 turn signal issues, need help
Hey all! so I have a 93 fxrs-sp....
the original turn signals have been gone for a long long time now, never had the fronts from what I remember. At one time, I installed some little bullet lights in the rear and they worked for some time. I know some lights have issues because they need some sort of resister added. Ive also heard something about needing the fronts for the rears to work but for a while I had the rears only and they worked for a few months. Now, I noticed for a few months now the rears quit working on me too. I pulled them apart and the light innards were really corroded.
So here I am, I just installed an fxrt fairing and I want to get both front and rear lights working again and I'm trying to track down why the lights are not working. I opened up the hand controls and I have power going to the hand control. Where the wires exit the hand control I get power out when I press the signal button. I traced the wires out and I have power all the way to the turn signal module and I still have power out from the thumb switch all the way to the turn signal module. From there I'm lost on what to test next. I don't know of a procedure to test the module if there is one or if I can test it coming out somehow.
Any words of wisdom? what else to test from there? how to test the module? or bypass it all together If I have to be ghetto I'm even debating just hardwiring the lights straight from the thumb switch and tap the switch to activate the switch with a press/release/press/release type of deal haha,
Old Jul 31, 2017 | 06:48 AM
grbrown's Avatar
grbrown
Wink
From what you describe I suspect the module is dead. If you want to use LED lights then you will need a 'ballast' to correct an old style of flasher unit, as LEDs take very little power compared with traditional incandescent bulbs.
I suspect your FSM will have a test procedure for the module, however if you want to use LEDs, then replace it with a single LED-friendly module, such as from Badlands. They do a wide range of suitable modules, for use with or without LEDs.
Old Jul 31, 2017 | 01:08 PM
hames93fxr's Avatar
hames93fxr
Stage IV
Default turn signal isses
Looks like its the module, I used a jumper to jump the plug without the module and I got power to the rear taillights. If I do go with an aftermarket module like a badlands, are they an either or kinda thing for led or not. I am running incandescent bulbs rite now. dont know if I will eventually go to led.
Old Jul 31, 2017 | 04:23 PM
grbrown's Avatar
grbrown
It's quite a while since I bought my Badlands module, so check their website. I think you will find they do 'normal' and LED versions of their flasher module. They also do an LED ballast module, if you change your mind later.
Fingas74
EVO
Jul 27, 2019 01:35 PM
j_mathis
Electrical/Lighting/Alarm
May 25, 2018 12:47 PM
dcloned
Jun 1, 2013 06:53 PM
dustyn2007
Jul 9, 2012 06:40 AM
UT-rckr
Jan 9, 2012 01:42 PM
