1993 Heritage Classic
Old Aug 14, 2017 | 08:21 AM
ChicagoSlim's Avatar
ChicagoSlim
Stage III
Default 1993 Heritage Classic
I have been looking for an Evo Softail for a while, and found one that has been 'dry stored' for 25 years and only has ~980 miles from new.
It was supposedly 're-commissioned' two years ago and underwent an MOT (vehicle safety test in the UK) and passed with the only advisories being the tyres were original and probably should be changed soon and the same on the brake hoses. The seller mentioned something about some engine internal plastic components that he was told should be changed as well.
Now the questions;
What should I be looking at on something with so few miles? I know the standard Evo issues, like base gaskets and case cracks in the lifter block area, but is there anything else for that year etc.?
Also, what plastic components could he have been told about? The only things I know that are plastic/nylon are, the primary chain guide and the breather valve. Is there anything else?
Thanks in advance
Old Aug 14, 2017 | 08:24 AM
Uncle G.'s Avatar
Uncle G.
The breather gear and primary shoe are the only internal plastic components I'm aware of. I ran the plastic breather gear for nearly 100,000 miles in my motor without incident. It still looked like new when I replaced it. I replaced it with another plastic gear.
There is a reason the MoCo uses a plastic gear. If any metal particles find their way into the breather chamber they'll embed themselves harmlessly in a $10 plastic gear instead of your expensive engine cases. If something's going to get chewed up, I'd just as soon it's a cheap breather gear.
Old Aug 14, 2017 | 08:25 AM
lionsm13's Avatar
lionsm13
Welcome to the forum
Old Aug 14, 2017 | 10:43 AM
grbrown's Avatar
grbrown
Thumbs up
Jolly well done old chap - quite a find. The things you mention only make themselves apparent, when they arise, after a decent mileage, so don't allow yourself to be distracted at this stage. The things to consider replacing IMHO, to make your bike serviceable, are:
  • tyres, including valve stems,
  • brake hoses - be aware your bike uses DOT5 brake fluid,
  • fuel lines,
  • change all oils, three reservoirs, plus front forks.
The carb may well need a strip and overhaul, although if it runs OK, see how things go. Use aftermarket braided brake hoses, from the likes of HEL.
Buy yourself the factory service manual, available from your local friendly dealer, not any of the cheap and nasty aftermarket brands. You may also have to consider wheel bearing rubber seals, even the bearings themselves. As it has been standing for so long they may suffer from local failure, where the rollers have been pressing on the races (called Brinelling).
Last edited by grbrown; Aug 14, 2017 at 10:56 AM. Reason: Removed reference to engine mounts!!!!
PanHeadRich
EVO
14
May 28, 2019 03:55 PM
Crazy16
EVO
32
Apr 12, 2019 01:16 PM
ChicagoSlim
Aug 14, 2017 08:11 AM
Bumpandrun
EVO
Mar 12, 2013 01:58 PM
mbierbac
Exhaust System Topics
Feb 6, 2012 02:20 PM
