Inner Primary seal question
Old Aug 17, 2017 | 02:47 PM
husky390's Avatar
husky390
Originally Posted by Beemervet
Way too much.
Yeah, after speaking with a local Indy shop I figured that out. My fault for going by the previous owners notes instead of what was printed in the manual. I'm pulling the inner Primary tonight.
Old Aug 17, 2017 | 09:21 PM
husky390's Avatar
husky390
Not much left of that seal.
And quick question. Does this flywheel look normal? It looks like someone drilled some metal out.
Old Aug 18, 2017 | 02:54 AM
LQQK_OUT's Avatar
LQQK_OUT
That's not a flywheel. It's the rotor assembly (part of your alternator). Looks normal.
Take a look at mine. I'm the original owner and it's never been touched. My guess is that's done at the factory to balance it.
Old Aug 18, 2017 | 07:42 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That's your rotor and yes that's normal.
That's exactly why they did it.
Old Aug 18, 2017 | 08:01 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Were any of the inner primary bolts loose going to the case? I've seen broken lips on the case before but never just mutilated seal. Wonder if someone was in there prior to you?
Old Aug 18, 2017 | 08:29 AM
husky390's Avatar
husky390
It's very likely someone has been into it prior to me as the bike has 72,xxx miles and the factory manual that came with the bike has the transmission chapter ear marked. But all of the bolts were tight.
Thanks for for correcting me on the terminology as all of this is new to me. Also, is there a torque sequence to follow for the inner primary cover? My manual is pretty vague on the whole procedure and only gives me torque specs.
Old Aug 18, 2017 | 08:36 AM
carlgrover's Avatar
carlgrover
what manual are you using? If it isn't the factory manual I'd recommend getting it and the factory parts manual. It will pay for itself on this job alone.
carl
Old Aug 18, 2017 | 08:59 AM
husky390's Avatar
husky390
carl
It's the factory manual. It worked great for the engine project I did but short on details for this.
Old Aug 18, 2017 | 09:35 AM
LQQK_OUT's Avatar
LQQK_OUT
My 1993 softail service manual says:
To get a good primary case alignment, the engine and transmission-to-frame fasteners must be loose.
--> I've never loosened those fasteners the few times I removed the inner primary
replace locktabs if necessary
Attach inner primary to the transmission, do not tighten
Attach inner primary to the engine. Tighten to 18-22 ft-lbs (engine/inner primary bolts)
Make sure inner primary does not bind on the mainshaft
Tighten transmission/inner primary bolts to 18-22 ft-lbs
Old Aug 18, 2017 | 09:57 AM
husky390's Avatar
husky390
Thank you.
