Inner Primary seal question
Old Aug 18, 2017 | 04:46 PM
glidein wide's Avatar
glidein wide
When inner is in place but still loose make sure the large o ring is still in place,use a mirror and light. They can fall if some jiggling is done while installing. Looks like the old one was pinched out of the groove,they don't usually look like that condition.
Old Aug 18, 2017 | 08:46 PM
husky390's Avatar
husky390
Thank you
Old Aug 18, 2017 | 08:49 PM
husky390's Avatar
husky390
Does anyone know what this blue crud is? It's all over the place where the starter pinion enters the primary and on the tensioner bolt. Looks like it may have been a seal in its past life?
Old Aug 19, 2017 | 08:14 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I suggest that since you have the inner primary cover removed, that you go a little deeper and replace all the seals on the left side of the transmission.
Inner primary cover oil seal 12052A
Starter jackshaft seal on inner primary cover 12066A
Inner primary bearing inner race on mainshaft 34091-85A
Pulley spacer 33344-94
Quad seal (underneath the pulley spacer) 11165
Shifter shaft seal on transmission 12045
Inspect the splines on the shifter shaft, if they are damaged now is the time to discover it.
When you go back together, use a new bolt on the shifter shaft, locktite it and get it tight...
Old Aug 19, 2017 | 08:35 AM
husky390's Avatar
husky390
I'm replacing most of those currently to get me back on the road until winter. Then I'm going to do this all over again so I can replace the belt and trans seal once I buy the socket. Good call on replacing the shifter bolt. I was just going to loctite mine.
Old Aug 19, 2017 | 08:42 AM
glidein wide
Add to that list...crank seal under the rotor while you're there and make sure it faces the right way.
Old Aug 19, 2017 | 01:02 PM
WP50's Avatar
WP50
Some kind off assembly lube or grease maybe?
Don't think that was a seal at one time .
WP
Old Aug 19, 2017 | 04:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I would leave that seal be.
The seal on my `89 FLSTC has been working fine for the past 90,000 miles so far, and it is facing the wrong way...
I don`t think it makes a difference.
Old Aug 19, 2017 | 08:46 PM
husky390's Avatar
husky390
She's back together and one test ride on it so far. Found one little drop of oil and I hope that's residual. Thanks everyone for your help.
Old Aug 20, 2017 | 09:08 PM
husky390's Avatar
husky390
Well, we put in 198 miles of 2 up riding and so far no leaks. Thanks everyone for your help.
Hipolito
Jul 29, 2018 08:29 PM
DHubbs
Apr 29, 2012 09:23 PM
IRONCAM
Oil Archive (no new posts)
Sep 15, 2010 08:01 PM
frozensoul
Aug 7, 2010 07:33 PM
