Clutch Problem
Old Aug 25, 2017 | 06:24 PM
RLH3175's Avatar
RLH3175
Now all I need is a 1 7/8" socket, about 10" long.
Old Aug 25, 2017 | 07:28 PM
glidein wide's Avatar
glidein wide
J&P Cycle,not cheap but worth having,you'll probably use it more than you think. And it comes with the shaft protector that screws on to it.
Old Aug 25, 2017 | 07:32 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Or if you want to go the cheap way and know someone with a welder you can make your own. That's what I did.
Old Aug 25, 2017 | 07:44 PM
glidein wide
I'm assuming that the comp sprocket and clutch pack all checked out fine ??? And the inner primary is off and it's definitely the pulley that is toast ???
Old Aug 26, 2017 | 06:56 AM
RLH3175's Avatar
RLH3175
The pulley is toast, the lock on the 1 7/8" nut was loose and it looks like the 1 7/8" nut has backed off some, want know for sure what all will need to be replaced until I get the pulley off.
Old Aug 26, 2017 | 07:03 AM
glidein wide
Was the cap screw missing? For the big nut... Did the big lock washer with the tabs break apart ?
Old Aug 26, 2017 | 10:19 AM
RLH3175's Avatar
RLH3175
This model has a lock plate with two allen screws, one allen screw was broke off and the other was backed out 1/4".
Old Aug 27, 2017 | 06:42 PM
RLH3175's Avatar
RLH3175
When the screws backed out, they chewed up the back of the inner primary cover, don't know if it will be usable, will clean it up and check it out.
Old Aug 29, 2017 | 05:04 PM
glidein wide
Do we have some pics on the way ?
Old Aug 29, 2017 | 06:09 PM
RLH3175's Avatar
RLH3175
Pictures of back of inner primary
Attached Thumbnails Clutch Problem-img_20170829_180411207.jpg   Clutch Problem-img_20170829_180403835.jpg
