So basically I blew out the master cylinder, new brake line, and bled the system using an entire container of Dot 4. I've checked the master cylinder as well as bled some off through the bleeder Ina tube and no signs of geling up or residue. Brake lever is tighter than ever before so we will see.
The gelling would not show up real fast. You have probably done some good and very possibly be good to go.
If time permits one thing I myself have done is to flush the system with denatured alcohol. Did this when Dot 5 was added to a Dot 3/4 system on some customers vehicles and a couple of bikes metric bikes in the past.
If there were problems latter on I haven't heard about it.
You may well ask! Whoever came up with that in DOT should be shot!
DOT3, DOT4 and DOT5.1 are all related and compatible, they are simply successive specs for polyethylene glycol-based brake fluids. Wiki can probably explain each in greater detail. DOT5 is a silicone-based brake fluid, which unlike the other three is not water-absorbing, hence it's attraction. Unfortunately it cannot cope so well with the mechanical action of current ABS systems, hence they have resorted to DOT4.
Dot 5.1 came out for the military, therefore you had Dot 3&4 for the everyday market and Dot 5 for military. When they came out with the new remake of Dot 4 they went with 5.1 cause they couldn't use 5.
