Help with Starter Bolt
Old Oct 1, 2017 | 06:26 PM
FreedomRider's Avatar
FreedomRider
Default Help with Starter Bolt
Bike is a 1996 Road King ... need to remove the inner primary to replace seals, I have a FSM ... I am able to get the rear starter bolt loose ... the front is another story, it is very tight and does not want to budge ...
any suggestions on how to get it loose ... I have not tried heat or soaking it with WD yet ... I did try an impact wrench with no luck
Old Oct 1, 2017 | 06:42 PM
johnjzjz's Avatar
johnjzjz
long extension universal allen and an adapter to 1/2 inch 12 inch braker bar and snap it off its locked spot - only way
Old Oct 1, 2017 | 07:07 PM
FreedomRider
I just went out tried this ... it worked!!!! The bolt came lose. Thank you very much. I knew there was a lot of knowledge here.
Old Oct 1, 2017 | 07:57 PM
johnjzjz's Avatar
johnjzjz
never seize the threads going back in, for some reason water like to weld the 2 allens in place - we run a touch on the allen head as well
Old Oct 2, 2017 | 06:54 AM
FreedomRider
I will use the anti seize for sure ... I was going to use it on the threads ... thanks for the suggestion of using it under the head as well ... great idea
PaulBartell
Engine Mechanical Topics
Nov 29, 2018 07:48 PM
IceMedic75
May 30, 2014 01:25 PM
RollieB
Mar 30, 2014 06:38 PM
Evilution
Apr 15, 2008 06:39 PM
Jameson
Jul 7, 2007 04:16 PM
