seat mounting
Old Oct 8, 2017 | 05:45 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by Mach1diesel
Interesting. On my 94, the seat does not mount to the green holes shown above. The only screw for the seat goes into a hole where 0maha has a yellow circle. The handles arent mounted there on mine. I dont have the bike with me, but i can take some photos next week when I do.
Yours is the first model year for several changes H-D made. For example your oil tank is under the transmission, instead of being an oil bag under the seat and your oil filter is up front, instead of being under and behind the transmission. Not least, your battery is under the seat!
Old Oct 8, 2017 | 02:30 PM
Mach1diesel's Avatar
Mach1diesel
I started suspecting something was different when i saw the saddlebag in 0mahas pic... welcome changes in my opinion.
Old Oct 8, 2017 | 04:37 PM
Wodan's Avatar
Wodan
For what it may be worth, the 93 frame is the same as the 94 to 96 year models, so their two piece seats should fit and use the same tank and fender 3 holes fitting.
Plenty of them around.
1997 and up is out of your picture.
Old Oct 9, 2017 | 08:17 AM
Jagg11's Avatar
Jagg11
I own the very same model and have converted move to let's say a 93.5 road king. You have the 3 choices. On my bike I can run any seat from the original all the way up to 07. Now you can take that back tab of you don't want to keep the stock luggage rack and bend it down and put a quick fastener in the fender. You bend the tab down on newer seats and most work and you can cut a slot in the frame and run some seats that way. I have 3 seats for my bike, a factory style mustang seat that I bet the rear tab down because I have a newer style rear, I have a lepera from an 05 touring that I just bevy the tab up and contour the bottom a little and a sundowner that came off an 03 that works well in the slot I cut in the frame.
Old Oct 9, 2017 | 08:38 AM
Jagg11's Avatar
Jagg11
My 93.5 road king(93flhs)
Old Oct 19, 2017 | 06:55 PM
kdunn's Avatar
kdunn
4th Gear
I'm tryin' to figure out how to post pictures of my bike, kinda techonogically challenged......
Old Oct 19, 2017 | 07:04 PM
Jagg11's Avatar
Jagg11
Old Oct 19, 2017 | 07:17 PM
JeremyB's Avatar
JeremyB
I like pics too!!! But sadly I can't see any. WAAAAAA
Old Oct 19, 2017 | 11:30 PM
Windseeker's Avatar
Windseeker
I wish you luck in your search. I myself am puzzled as to why some seats mount with the bolts on the side, like my Le Pera, while others use the single bolt on the fender.
Old Oct 20, 2017 | 01:59 PM
kdunn's Avatar
kdunn
4th Gear
I did it! Crappy pictures with my flip phone, but give me a break, I'm old!
