evo kill switch
Old Nov 3, 2017 | 07:19 PM
  #31
Ruggs59's Avatar
Ruggs59
I never use the kill switch to turn the bike off. The couple times i did, I forgot to turn the ignition off which leaves the lights on..
Old Nov 4, 2017 | 06:31 PM
  #32
nibroc's Avatar
nibroc
my 99 heritage has never been turned off with the kill switch----except when my daughter rides it
Old Nov 5, 2017 | 09:16 AM
  #33
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I have been using the kill switch to shut off the engine on my `89 for 28 years, never had a problem, still the original switch.
I agree with Ranger73, the alarm may be causing the issue, you should not have to shut the ignition down a certain way just to make the alarm happy...
What do you mean when you say won`t start, does the starter crank the engine, or does the starter not work?
Old Nov 5, 2017 | 10:01 PM
  #34
im's Avatar
im
What kind of alarm?
Does it have a key fob ?
What do you have in addition to key?
It might be an alarm issue or maybe a kill switch issue.
A key fob uses a battery.
Old Nov 7, 2017 | 02:59 PM
  #35
ronks2's Avatar
ronks2
Quick question before I go into my rambling. Does your bar switch feel new and notchy with a crisp click? Or does it feel more like a smooth squish? One of mine is squishy.
I have a couple of Evos, and one has this problem as well. If you shut it off by bar switch it may or may not turn over again. I tried starting her on the first key click no lights and worked for a while but messed up again. Had an extra key switch so I threw it in and worked fine for awhile as well. I did notice that if I ran her everyday she was more forgiving on starting.
Long story short I am leaning toward the bar switch as well.
fireman031967
Oct 6, 2014 02:02 PM
theabominablenick
General Topics/Tech Tips
Jun 11, 2014 10:40 AM
$eventy2T
Sep 10, 2013 08:38 AM
UT-rckr
Jul 18, 2011 07:48 PM
masterblaster
Dec 11, 2010 08:12 AM
