Starter issues...Need some additional advice
Old Nov 3, 2017 | 07:22 PM
mdewberry's Avatar
mdewberry
Default Starter issues...Need some additional advice
First off,,,, I'm back!!! Just picked up a sweet deal on a 1995 FLSTN 22,000 original miles from a widow woman that spent 3 years in probate!!
One major problem it won't start.
Push start... yes it runs!! Mama is tired of pushing!!
Battery was 4 years old ....Got a new one 325cca.. Battery charger is always connected.
Starter spins doesn't engage... Replaced Starter Clutch..nogo
Starter Relay replaced and yes the old one did work... Voltage is a issue. going to try the additional relay setup
Installed push button on starter .. still spins
Replaced ignition switch that was rusty and cleaned all connections... All Grounds and Molex Connectors cleaned
Jumper wire from Battery to starter solenoid and it spins. Additional relay can fix this
Could this be a bad jack shaft? I have searched the hell out of the forums and have give up...Any suggestions would be appreciated
Old Nov 3, 2017 | 07:28 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
First off you don't need an additional relay.
All you need is a 20 amp fused wire going from the positive post to pin 30 on the relay.
Second you say it spins and doesn't engage...
Have you looked in the primary at the starter drive gear and the starter ring gear?
BTW you have AMP connectors not molex on a '95 Softail.
Old Nov 3, 2017 | 08:00 PM
mdewberry's Avatar
mdewberry
After thinking about the relay and the room needed. I agree on the fused wire to pin 30.
Gonna take the primary cover off tomorrow and see what it is doing. Spent 6 hours on it today and buttoned everything up. Thankfully I didn't fill the primary.
Old Nov 3, 2017 | 08:17 PM
Dr.Hess's Avatar
Dr.Hess
Yeah, I'm going with your problem being in the primary (starter clutch included) or the starter solenoid. It may just need a good cleaning. An extra relay, extra wire, etc., is not going to help you out.
Old Nov 3, 2017 | 08:32 PM
mdewberry's Avatar
mdewberry
Replaced starter clutch this afternoon with a new one, hoped that would fix it...
Dr. Hess I will send PM....
Old Nov 6, 2017 | 07:28 PM
Dr.Hess's Avatar
Dr.Hess
So... Is it running?
Old Nov 9, 2017 | 09:30 PM
mdewberry's Avatar
mdewberry
Not yet!! Friday afternoon project....Gonna look at the jackshaft coupling
Old Nov 10, 2017 | 09:43 AM
Dr.Hess's Avatar
Dr.Hess
OK. Gotta be something like that, or teeth on the clutch basket and it's been a while since I was in one, but isn't there a little arm that pushes the gears together? Rides in a groove? If the starter motor is spinning, the solenoid is working.
Old Nov 11, 2017 | 10:35 AM
rol427's Avatar
rol427
TexasHillCountry,
"All you need is a 20 amp fused wire going from the positive post to pin 30 on the relay."
Is the positive post the battery terminal? Is this wire in addition to the factory connection?
Old Nov 11, 2017 | 11:51 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
To keep the battery terminals less cluttered, you could run that wire from the main breaker.
