Oil Pump Upgrade......
Old Nov 7, 2017 | 08:57 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Oil Pump Upgrade......
A couple of weeks ago I was out for a ride with friends (11) any ways we pull into a gas station and oil is spewing out from behind the primary. With in 15 seconds it left a puddle the size of a grapefruit... So I shut it off and checked the oil tank... No reading on dipstick but can see oil in tank. So I whipped everything down bought a quart of oil started it up and it stopped... Weird I thought, so when I got it back to the shop I started to tear into it... The sprocket shaft seal was leaking. No damage to anything, crank seemed tight in the bearing as well... I didn't have any unusual motor vibrations either. So I removed the timing inspection plug and while is was turning the motor over by hand and a socket on the crank I noticed an excessive amount of oil being picked up by the crank wheels. The drilled balance holes on the wheels were full with oil.. So the only thing I could think would cause this was the pump was not scavenging or the check ball was stuck.
So I took the pump off to inspect and clean found nothing out of the ordinary... With the case full of oil there must be something going on so I decided to order a new S&S HVHP pump..
I thought that this would be an easy swap out. Man was I wrong. I never did have to mess with an oil pump before. So in the process of replacement I have learned that the only way to do it right is that I need to disassemble the entire cam chest to make sure that the pump shaft will not bind after aligning it...
So that's where I'm at for now. I'm pretty confident that it all started with a sumping issue... Time will tell...
Old Nov 7, 2017 | 10:20 AM
daven9113's Avatar
daven9113
Interesting. Let us know how it turns out.
Curious, do you have a bottom end breather? Where was the oil spewing from?
Old Nov 7, 2017 | 11:19 AM
Beemervet's Avatar
Beemervet
Old Nov 7, 2017 | 11:59 AM
98hotrodfatboy
No, top breather... 98 modified 96" Evo...
Old Nov 7, 2017 | 06:29 PM
johnjzjz's Avatar
johnjzjz
a seal divides the pump in and out - have seen that happen - the last one was a knucklehead with an alloy pump not the correct iron oil pump , the last install was incorrect as they influenced the drive shaft to one side of the pump and caused excessive alignment issues with the shaft / pump body and seal
it also hurt the oil pumps bushing in the block on the one I had
hold the old pump in your hand No gears just the shaft in the correct location and wiggle it back and forth as you look at the seal - now look at the seal and the amount of travel the shaft has 1/4 inch is fine more then that - is the issue its transferring the oil from the return gears back into the feed gears not going to the oil tank, and that will empty the oil tank and fill the engine
the one I had recently blew the oil tank empty in a hurry
Old Nov 7, 2017 | 06:54 PM
98hotrodfatboy
I will do that.. thank you John.....
Old Nov 8, 2017 | 03:56 AM
Evoken's Avatar
Evoken
The s&s hvhp pump is a nice product, and yes a pain in the *** to change. Especially if you have sausage fingers like me. Mine helped cool down and lubricate really well.
Keep you eyes open hotrod. They push so much harder that any little imperfection in your gaskets will show up. My rocker box top bolts are still weeping just a little bit. I had to go through especially the rockers and torque to make allowable on all gasket mating areas to get little weepers dried up.
Old Nov 8, 2017 | 05:35 AM
98hotrodfatboy
I thought they were only a high volume pump and not high pressure.? I'm really looking for the supposed better scavenging.... Thanks for the info. I will pay close attention.
Old Nov 8, 2017 | 06:50 AM
Prot's Avatar
Prot
From your original post:
S&S HVHP
that means high volume high pressure.
Old Nov 8, 2017 | 06:59 AM
98hotrodfatboy
Prot, I know what they advertise but I have heard through the grapevine (HD Forums) that because of the way the oiling system and ports are designed on our Harley's that pressure increases are not to be expected. At the pump yes but not throughout the motor... So we'll see.....
