Oil Pump Upgrade......
Old Nov 8, 2017 | 08:33 AM
Evoken's Avatar
Evoken
My pressure at idle went from 8lbs to about 15lbs, maybe a touch more. Not sure what it is now, I removed the gauge and haven't replaced it yet. That was at the tappet screen.
Old Nov 8, 2017 | 05:44 PM
johnjzjz's Avatar
johnjzjz
Prot, I know what they advertise but I have heard through the grapevine (HD Forums) that because of the way the oiling system and ports are designed on our Harley's that pressure increases are not to be expected. At the pump yes but not throughout the motor... So we'll see.....
knuckle pans and shovels have an oil light, the light pressure switch turns the light on a 3 to 4 pounds idling hot and many older machines it will blink at idle, its not a car engine
the introduction of hyd lifters in the 1950s on to 1972 took priority oil pressure, and part time to the lower unit and the top end was secondary oil pressure
in 1973 to 1984 they made an attempt to up grade the system, but still the lower unit was not primary with oil pressure and no one has tried to make it primary
very few shovels will not smoke with 15 pounds of oil pressure at hot idle - a miracle has to happen to keep them from leaking with that much pressure and volume
but they do have over 100 pounds cold for a few minuets - reinventing an engine design 30 plus years after the last one was built might be a mistake
evos on the other hand want more as they have a car type hyd lifter and they are not primary pressure to the lower unit as well, evo switch comes on at 6 to 8 pounds
Old Nov 8, 2017 | 09:24 PM
1997bagger's Avatar
1997bagger
I run the S&S oil pump, it's gears are about 1/4" wider in depth than a stock pump. Took the Ultima pump apart also and it is identical inside compared to the S&S, the Chinese copied it to a tee.
Old Jun 3, 2018 | 03:40 AM
Daedalus's Avatar
Daedalus
Does the S&S HVHP have a polished cover, or is it chromed aluminum? I hope its the first, but fear its the last...
Old Jun 3, 2018 | 07:17 AM
98hotrodfatboy's Avatar
98hotrodfatboy
It is polished. Believe it says so in the description... Chroming an oil pump can lead to clearance issues down the road..
Old Jun 3, 2018 | 09:13 AM
Daedalus's Avatar
Daedalus
Due to the high volume output, there will be more oil fling of from the big end towards the barrels. Good for cooling and lubrication, but did anyone notice an increase of oil consumption with these pumps? In other words, do the oil scrapers manage to get rid of the extra lube?
Old Jun 3, 2018 | 07:09 PM
johnjzjz's Avatar
johnjzjz
its a 2 fer more in and the ability to get more out so all it does is circulate more
streetglide99
Shovelhead
16
Oct 23, 2014 03:06 PM
ronnie41653
Oct 23, 2013 08:48 AM
doug9270
EVO
15
Oct 10, 2013 04:14 AM
gnafin
EVO
39
Jul 7, 2013 05:52 PM
istoleurpen
Jun 8, 2006 08:40 AM
