Head bolt Stud
Old Nov 28, 2017 | 06:00 PM
Ruggs59's Avatar
Ruggs59
Default Head bolt Stud
Progressing to replace my head with a screamin eagle set. One of the studs came out instead of the bolt coming off. The case threads are not striped or any of the nonsense. Whats the opinions here on putting it back in? Loctite? Red or blue? or just put it back in as is? I am going to use new bolts as they all were pretty corroded on the inside thread area, hence why one stud came out. The others 7 studs are all nice and tight.
Old Nov 29, 2017 | 06:54 AM
johnjzjz's Avatar
johnjzjz
leave well enough alone with the other studs would be what we would do - and clean the stud that came out, red loc tite it back in and put the top end on = dont go looking for trouble doing anything else
Old Nov 29, 2017 | 07:08 AM
Hoginedgewood's Avatar
Hoginedgewood
I’d inspect the bolt and bolt hole, then I’d get the book out and follow directions for putting the stud in.
Old Nov 29, 2017 | 07:43 AM
WP50's Avatar
WP50
Red has done well for me in situations like this.
I have cleaned up the stud and reused them with no problem.
WP
Old Nov 29, 2017 | 05:58 PM
Ruggs59's Avatar
Ruggs59
Thanks for the advice. Red it locktite it is. THe FSM didnt specify as it assumes you are using a new stud and they come pre gooped with it. I did but new head bolts today. The base gaskets on the cylinder sure are a bitch to get off. 1.5 hours in and i have only 1 cylinder half way done. you can also see the hole that has rust and corrosion in it where the stud came out with the head bolt. Im using plexiglass to scrap the gasket material off. sharpen tap a few time and repeat. NO damage to the base area what so ever using the plastic as a scraper .
Old Nov 29, 2017 | 07:30 PM
Dr.Hess's Avatar
Dr.Hess
You know they make plastic razor blades, right?
Old Nov 29, 2017 | 08:06 PM
Ruggs59's Avatar
Ruggs59
Now you tell me! LOL No i did not. I got one barrel done. Honestly I doubt a plastic razor blade will touch it. Those gaskets are like iron.
Old Dec 1, 2017 | 10:39 AM
Yankee Dog's Avatar
Yankee Dog
Put some paint remover on that gasket and let the paint remover soften it up for awhile, or at least some heat...just be careful with the paint if your cylinder is painted. YD
Old Dec 1, 2017 | 11:35 AM
apples402's Avatar
apples402
Commercial kitchen product. Carbon off really nasty oven cleaner works like a charm. Should be at any restaurant supply store.
Old Dec 1, 2017 | 02:52 PM
Ruggs59's Avatar
Ruggs59
I got it done. Next question is? thought on copper coat on the base gaskets? I'm using cometic Steel Viton coated base gaskets.
