Head bolt Stud
Old Dec 1, 2017 | 06:58 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Ruggs59
I got it done. Next question is? thought on copper coat on the base gaskets? I'm using cometic Steel Viton coated base gaskets.
I wouldn't.
Old Dec 1, 2017 | 07:25 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by texashillcountry
I wouldn't.
thc, why?
Old Dec 1, 2017 | 08:45 PM
texashillcountry
Dirt don't hurt
thc, why?
The surface looked good and I see no reason to use it.
So far I have used Cometic SLS and MLS base and head gaskets without copper coat and they sealed up great.
Old Dec 2, 2017 | 08:17 AM
Ruggs59's Avatar
Ruggs59
THC is there any down side to using it? A little extra insurance surely can't hurt right? Im only refering to the SLS base gasket
Old Dec 2, 2017 | 09:38 AM
texashillcountry
Dirt don't hurt
A couple possible down sides is you get too much on the surface and a bit could either partially block or totally block that oil passage.
The other off the top of my head is it will be harder to clean the surfaces if you have to do the job again.
I'm a firm believer in the KISS theory.
All that said its your bike do what you want.
Unless the gasket surface was mess up in some small way I wouldn't.
FWIW a friend of mine had his top end done by a shop and the base gasket wept from day one.
I went and replaced the top end gaskets with SLS and MLS Cometic gaskets and the weep is gone and has stayed dry for the last 5 years.
Old Dec 2, 2017 | 10:55 AM
Schex's Avatar
Schex
There's a right way and a wrong way to use it, Tex mentioned the wrong way,
I use it unless I'm dealing with fresh machined or near perfect surfaces, then it still wouldn't hurt if you don't slop it on.
Clean the surfaces dry and oil free with brake cleaner,
have something to hang the gasket on before spraying,
spray the gasket with thin coats just enough to cover,
let it dry about 10-15 minutes, depending how thick you sprayed it,
assemble,
use brake cleaner sprayed on a rag to wipe off the copper coat that's visible around the gasket area, wipes right off.
Old Dec 2, 2017 | 03:55 PM
WP50's Avatar
WP50
if your gonna use it ____ Very light coats. it doesn't really take much at all.
WP
Old Dec 2, 2017 | 06:20 PM
Ruggs59's Avatar
Ruggs59
Aint they Purdy! For those who want to know i did chose to use the spray. every thing is torqued down using cometic's spec. Im stopping here untill tomorow so i can check the torque again.
Old Dec 2, 2017 | 08:25 PM
WP50's Avatar
WP50
Aint they Purdy!
What the ___ Are ya a NY redneck or sumptin
Looks good Dude
WP
Old Dec 3, 2017 | 03:52 PM
flhchaz's Avatar
flhchaz
Lookin’ good
