Upgrading the trans
One thing I had to do is swap out the stock clutch with a later model that will fit the splined output shaft of the new trans. The stock clutch, which I have broken a hub on once already is for the tapered shaft and key way style. Already have a complete clutch from a 2003 that was given to me, just needs a minor repair and a couple of pressure plate bolts. Won't be sorry to see that old clutch go.
If most of your riding is in town, Red Light to Red light, then every fear lower with 6 providing direct drive would be the better choice.
What engine mods do you have? What cam? Is it Stock displacement? These things are also a factor.
Strictly speaking the OD6 is an overdrive trans, in which the output shaft is turning over slower than the input shaft, when in top gear. The attraction of a DD6 is that input and output shafts turn over at the same speed, when in top, when it should also be more efficient. With over 100HP/100TQ I expect Hyacinth to be able to routinely run in top gear.
Hope that helps!
That's why Baker recommends you get a different compensating sprocket which turns 6th from 1-1 to .86-1.
I do mixed riding, mostly out in the country on back roads where the speeds are 50 or less and touring where i'll take the expressway to get to the good back roads. Very little city driving. Bike has enough power to comfortably run 80 MPH on the highway with the gearing it has now and still return 40 + MPG. I'm a touring cruiser who also likes to drag the floor boards in corners and occasionally race my buddies on what ever they're riding.
Hope that helps!
