Turn signal problems
Old Feb 15, 2018 | 05:12 PM
14GuineaPig's Avatar
14GuineaPig
I don't think it matters which wire is connected to what terminal of the flasher, but if the flasher has a terminal marked "+", connect the Orange wire there.
Old Feb 16, 2018 | 03:18 AM
lillemann's Avatar
lillemann
In my book the orange wire comes from the rear brake switch. On my - 91 it's underneath the fram, it has the orange and a red wire.
Old Feb 21, 2018 | 06:00 PM
sB43's Avatar
sB43
I traced the wiring from the frame harness to under the rear fender. WHAT A FRIGGIN MESS!!!!! This guy was an absolute IDIOT!!! I bought new wires (colors to match) a new harness connector and new pins. I'm just waiting on my shrink tubing to come tomorrow. I also bought new 15 amp relays. I'll hook everything up tomorrow , (relays Friday). I made sure I have good grounds, clean connections, fresh wires, and new circuit breakers. If this don't fix it, I just don't know. I will have to be further up in the harness. This guy sliced and rigged everything he touched (wiring wise). I just did a complete tune up (And I went all out on the it), wires, plugs, coil, ignition sensor, rectifier, new jets, Cold air induction.........This bitch ROARS! Starts on the first hit of the button.
A shame these turn signals are the only thing keeping her off the pavement!
Old Feb 21, 2018 | 06:45 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You could always just use hand signals.
Old Mar 3, 2018 | 04:14 PM
sB43's Avatar
sB43
Thumbs up Problem solved My Brothers
It was the hazard light switch. Power going in, but not coming out. The switch effects all the lighting. Bought a (new used one). I had replaced all the wiring from the seat to the back. My buddy came in with some kind of wire probe thingy and found it. All good.!
Old Mar 3, 2018 | 04:22 PM
texashillcountry
Dirt don't hurt
Glad you got it sorted out.
Now go do your bit to help global warming and ride that thing!!!!
Old Mar 3, 2018 | 04:39 PM
sB43's Avatar
sB43
Ok, don't know if I can fix that much, let's just ride!
Old Mar 3, 2018 | 04:47 PM
sB43's Avatar
sB43
Old Mar 3, 2018 | 04:48 PM
sB43's Avatar
sB43
Now, ain't that purdyful!
Old Mar 3, 2018 | 05:46 PM
Beemervet's Avatar
Beemervet
Except for the hype o charger.
