Flat top or domed
Old Jan 31, 2018 | 08:26 AM
user 47363638's Avatar
user 47363638
Default Flat top or domed
Which is better and why.
Old Jan 31, 2018 | 08:46 AM
98hotrodfatboy's Avatar
98hotrodfatboy
It all depends on the type of build you are doing which decides what you need... To classify as which is better than the other? Don't believe any one is, providing you stick with the same manufacturer when comparing..
Might I ask what you are building?
Old Jan 31, 2018 | 09:44 AM
user 47363638
85” revolution performance kit, dome gives the higher compression, I had a brain fart, it’s been a while, thanks.
Old Jan 31, 2018 | 10:01 AM
Prot's Avatar
Prot
You need to look at what works best with the rest of the components you have, especially the heads.
Old Jan 31, 2018 | 10:54 AM
Mattbastard's Avatar
Mattbastard
I agree with 98, depends on the build. Sometimes if you go with domes you may need some head work to lower the CR back down to pump gas levels, but perhaps not depending on the height of the dome.
I personally believe in angled squish bands over domes. Much better flame propagation with a tighter combustion chamber while the squish creates turbulence to aid in a more complete combustion. Unfortunately they require a LOT more head work and custom pistons. The neat thing is if you have the S&S stroker crank for your EVO you can use Sportster 1200CC (and their variants) pistons as the pin height is within 25 thou of the Evo.
Old Jan 31, 2018 | 12:43 PM
misfitJason's Avatar
misfitJason
I like domes and here is why. I have found (from my last build) that I don't like when my heads are decked because it creates a problem with the intake manifold fit. I would rather have the chamber of the head cut out to fit desired compression by making the chamber bigger then to cut the head down
user 47363638
Evo Era Parts
Nov 23, 2020 09:27 AM
snowboarder
Jan 10, 2019 11:28 PM
allthefineprint@gmail.com
Sep 9, 2018 06:31 AM
